300 Baud for Mega 2560
Hello, when looping back my via
if (Serial.available()) { int inByte = Serial.read(); Serial.write(inByte); }
It only returns rubbish - when using 300 Baud With every other Baud rate it works.
I have read https://github.com/arduino/Arduino/commit/db64d2fc323219c3487947aa28bee07385c96a67
Do I get that right, that the Ports 1 and 2 will work with 300 baud?
How can I get my USB run with 300 Baud?
Thanks & regards Nils
The real question here is "Why do you want to use 300 baud"? For serial communication, that's ridiculously slow!
Indeed this is very slow - I would appreciate if my power meters I would like to communicate with would be faster. But there is no chance to speed those devices up =(
In arduino, set it to 600BAUD, then turn of double speed. (the baud rate will then half)
Serial1.begin(600);
UCSR1A &= ~(1<<U2X1);
Basically, the BAUD rate generator can only store 12bit values. By default Arduino turns on double speed, which means that the generator value is:
UBRRn = fcpu/(8BAUD) -1
For 300baud, this is
UBRRn = 16000000/(8
300) -1 = 6665.
This is a 13bit number, so cannot be stored. (If you try and save it, it will be truncated to 2569 = 6250BAUD, hence you have a problem)
By disabling the double speed bit, the calculation becomes:
UBRRn = fcpu/(16BAUD) -1
UBRRn = 16000000/(16
300) -1 = 3332.
This nicely fits into 12 bits, so you will be able to easily generate 300 BAUD.
This sounds great!!! 8) I will try this and give my feedback asap Thanks Cheers Nils
No - this Does not work :sleeping: But I will follow up on this later - perhaps I have to equip with another Peace of hardware which is faster :~ If not I will follow up
Thanks
This works for me:
  Serial.begin(600);
  UCSR0A &= ~(1<<U2X0);
  Serial.println("HI, I'm 300BAUD");
I see now that you wanted to send it through the USB not throught UART1. The code above communicates fine with the computer (through UART0 and hence the USB port) with x-ctu (terminal) set at 300 baud.
