Nikola19992:
but I need to make like 10 of theese and they need to be same.
I must be missing something! After you make the first one make 9 more!
Nikola19992:
I will.But how can a coil (diy transformer) be better than boost converter?
A boost convertor gives you dc, to which you then have still to attach an amplifier and a signal source to get the 30vac you require.
ie it doesn't do the job without a lot more gubbins.
The PM device you mentioned earlier will only stand 5v. So you'd have to find another one.
A simple transformer/555 does it all.
When I get a mo I'll draw you a circuit. I take it you're using a 12v power source?
Allan
An H-bridge is simpler than an audio amplifier. You'd just have to supply 30V (or 15V) and a square wave. Does it have to be a particular frequency? Does it have to be AC?
Unless it's been shown that a square wave works best, it's probably worth trying a regular ol' 24VAC transformer. 24VAC RMS has a peak of about 34V, and with a light load you should get a bit more than 24VAC.
Won't do 2kHz.
Allan
I need about 500-600Hz
Nikola19992:
Are you sure? How do you know that?
I'm not actually sure but it sholud work with like 600Hz.I'll experiment with it till it gives me best results
Nikola19992:
10:1 pulse transformer then
Since they are almost impossible to find I decided to make something using LM2577T.Can anyone check this out?
Nikola19992:
Maybe, but doesn't it make sense to try something easier first, like 50/60Hz?
I'll be trying alot of frequencies to find best one
