I'm working on a project to connect a 30W RGB Led to Arduino and manipulate it with MAX with maxuino.
in the photo you can see the connection that i'm using. The Mosfet is an IRF-Z44
The problem is with the PWM.
I've look in different post and themes on the web and I'm still blocked... With a normal rgb small led everything is ok, but when i connect the 30W rgb, either the arduino sketch with a potentiometre or the pwm output from maxuino works just as ON/OFF and not as PWM...
You need a [u]constant current power supply/driver[/u]. There are dimmable constant current (controlled current) power supplies that use 0-10VDC or 10V PWM to control the dimming circuit.
With "regular little" LEDs you can use a resistor to control/limit the current but with high power LEDs a switchmode supply is used because otherwise you'd need a big power resistor and that's inefficient and the resistor gets hot.
With your existing circuit, you have no current limiting/control and you are in danger of frying the LED, your power supply, or your MOSFETs.
Thanks for your answer...
So, there is something that i don't understand... These means that i can't use high power led via Arduino and so... via MAX MSP?
It means you can't do it with the circuit that you have. You can do it if you use a proper circuit that implements a dimmable constant current control for your LEDs.
No not for one LED, this is designed to dim a string of LEDs in series. The minimum output voltage is too high for just one.
Anf if is these, how can i control the three color in a separate way? Ther is just one 0-10V control input??
You would have to have three of these, one each for the red, green, & blue component. But your LED has a common anode so you can't put more diodes in series.
As that LED is a common anode design you need a constant current sink, not a source.
You need three of these circuits, one for each colour LED. You can make or buy things like this.
Search for :-
300mA constant current sink
As there are multiple LEDs in series inside this LED you will need a supply of 33V, or over. This means that the constant current for the red LEDs has to burn off more power than the others so that one will need a good heat sink.
If you do it will be a waste of money. That device is a constant current SOURCE not as told to you a constant current SINK.
That device would have worked if you had a common cathode LED but you have a common anode LED.
Then connect the common anode of the led to the Led+ of eache driver and each color to each led
Now, i'm preparing the circuit, but there is something that i don't understand, in the Datasheet they said the the i've to connect the LX pin to the Anode of the Led. So I've a common anode led, where i connect the Cathode of each color?
Well not according to the diagram on page 1 of the data sheet. That shows LX going to the inductor and the anode of a flyback diode. It shows the Anode connected to the supply voltage and the cathode to the other side of the inductor.
