315 Mhz transmitter and temp Help
im trying to send temp by 315Mhz transmitter
i got this code for the Transmitter and it worked
SimpleSend
This sketch transmits a short text message using the VirtualWire library
connect the Transmitter data pin to Arduino pin 12
#include <VirtualWire.h>
// Initialize the IO and ISR
vw_setup(2000); // Bits per sec
send("Hello there");
void send (char *message)
vw_send((uint8_t *)message, strlen(message));
vw_wait_tx(); // Wait until the whole message is gone
and this for the temp and it worked
//TMP36 Pin Variables
int sensorPin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade with a
                        //500 mV offset to allow for negative temperatures
 * setup() - this function runs once when you turn your Arduino on
 * We initialize the serial connection with the computer
  Serial.begin(9600);  //Start the serial connection with the computer
                       //to view the result open the serial monitor
void loop()                     // run over and over again
 //getting the voltage reading from the temperature sensor
 int reading = analogRead(sensorPin);
 // converting that reading to voltage, for 3.3v arduino use 3.3
 float voltage = reading * 5.0;
 voltage /= 1024.0;
 // print out the voltage
 Serial.print(voltage); Serial.println(" volts");
 // now print out the temperature
 float temperatureC = (voltage - 0.5) * 100 ;  //converting from 10 mv per degree wit 500 mV offset
                                               //to degrees ((volatge - 500mV) times 100)
 Serial.print(temperatureC); Serial.println(" degrees C");
 // now convert to Fahrenheight
 float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
 Serial.print(temperatureF); Serial.println(" degrees F");
 delay(1000);                                     //waiting a second
so i wrote this and i keep getting cannot convert ‘float’ to ‘char’ for argument ‘1 to void send(char*)’
SimpleSend
int sensorPin = 0;
 voltage /= 1024.0;
send(temperatureF);
help please
You'll need to convert your float variable "temperatureF" to the expected char type. Try the forum post below for further direction. I am unfamiliar with this process myself...
http://forum.arduino.cc/index.php/topic,43715.0.html
