Tonight I plugged in my new 315 MHz Trasmistter - Receiver from Ebay. I finally had them to work, I think.
Here is my code.
TX
#include <VirtualWire.h>
pinMode(13, OUTPUT);
vw_set_ptt_inverted(true);
vw_setup(2000); // Bits per sec
vw_set_tx_pin(3); //Tx pin
delay(500); //Send a message every half second
char *msg = "12321";
digitalWrite(13, HIGH ); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, LOW);
RX
int i =0;
Serial.println("Started");
vw_set_rx_pin(2); //Rx pin
vw_rx_start();
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
digitalWrite(13, HIGH);
Serial.print('\n');
Serial.println("Receiving data");
Serial.print('\n');
for (i = 0; i < buflen; i++)
Serial.print(buf[i]);
Serial.print('\n');
Serial.print("------------------------");
delay(10);
The questions are:
1 - What is that kind of variable : char *msg = "12321";
2 - If I send 12321 and I reveived 4950515049, how to put it back in 12321 format? Is it something like HEX TO INT?
It seem's that 49 is the start and end delimiter for a transmission, am I right? So what are those: 3 = 1 , 2 = 5 and 1 = 0.....
EDIT: I substract 48 from each value so I came back to 12321 I have tested with different value and everything is fine
3 - What are those kind of variable? uint8_t buf[VW_MAX_MESSAGE_LEN];
I have worked on arduino since a long time now and never seen those type of variable. Could it be replaced with some more common one?
Thanks for the help!
