I have had the pair for almost a week now and I have had no luck being able to connect them to work. I have various tutorials along with the datasheets that I used and I could not connect them because that is usually how I learn about the sensors I am using in my project. I got some new code that I thought would be nice for me to use considering the fact I just want to send simple messages back and forth using one pair of 315 mhz and one 433 mhz. Ok so the code I am currently using uploads fine and all but I haven't been able to receive anything on the serial monitor?
Is something wrong with the code or did I wire it incorrectly which I don't think is possible because I wired it the same way the datasheet from sparkfun had for both of them.
transmitter(mega)
// Arduino mega tx
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
vw_set_ptt_inverted(true);
vw_setup(2000); // Bits per sec
vw_set_tx_pin(3); // pin 3 is used as the transmit data out into the TX Link module, change this to suit your needs.
const char *msg = "String Sent"; // this is your message to send
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait for message to finish
delay(200);
receiver code (uno)
#undef int
#undef abs
#undef double
#undef float
#undef round
vw_setup(2000);
vw_set_rx_pin(12);
vw_rx_start(); // Start the receiver
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // check to see if anything has been received
int i;
// Message with a good checksum received.
for (i = 0; i < buflen; i++)
Serial.print(buf[i]);
Serial.println("");
Still nothing.
I even attempted to change the antenna by taking it out and then testing but nothing. I then put them back in the breadboards but still nothing.
The antenna's are close to 5 inches and are
normal wires. Also, I tried different distances less than a foot away and more than 3 feet away.
Should I try the 433 MHz pair to see if there is a messed up tx or rx?
I don't think so, I mean I haven't packages of the 434 yet due to the fact I didn't want to mix them up but they might have got mixed up in shipping ?
Do you think I should post pictures(or use a program to post the diagram) of the set up if i can't get them to work after seeing if they got mixed up ? That would be the only thing I can honestly think of being wrong if it's not the wrong pair.
Thanks.
Hey, I received a problem when I tested the volts and I posted this in electronics but I think I should have posted it here since I was able to today.
So,
My wiring is set up(from left to right) for my mega connected to the Transmitter by a breadboard with a 5v battery pack as the power source. First wire orange connected to ground, second wire green connected to digital pin 39(I tried various pins and it didn't work), third wire another orange connected to 5v, and fourth wire green used as an antenna extending out.
My wiring for the Receiver which is connected to my Uno through a BOE shield breadboard with a USB as the power source. Wiring from left to right: First wire green I have connected to ground, second wire yellow I connected to digital pin 5, third wire green I connected to ground, fourth wire yellow I connected to 5v, fifth wire yellow I connected to 5v again, sixth wire green I connected to ground, seventh wire yellow I connected to ground as well, eighth wire green was used as an antenna. https://www.sparkfun.com/datasheets/RF/KLP_Walkthrough.pdf is where I got the way to wire them, and is in the suggested links part for these models. RF Link Transmitter - 315MHz - WRL-10535 - SparkFun Electronics is the transmitter and RF Link Receiver - 4800bps (315MHz) - WRL-10533 - SparkFun Electronics
I have the 315 Mhz(one pair) and the same exact pair but a different frequency. I don't think the device is defective it has to do with one of the boards I believe. I scanned the volts coming out and It was really weird. When I scanned the two different devices with a 5v battery pack they were both 5v but when my uno had a USB connected to it it was 4.22 I just bought a new one because my old USB had different results with the mega having 4.23 and the uno having 3.67 volts.
