Hi, i've bought those 315 Mhz wireless modules : link
i tried to configure them and use as the following guide :
that is using pin 12 for data in the transmitter and pin 11 for data in the receiver,
for the code i used the RadioHead librari with the object RH_ASK as follow:
for the transmitter:
// Include RadioHead Amplitude Shift Keying Library
#include <RH_ASK.h>
// Include dependant SPI Library
#include <SPI.h>
// Create Amplitude Shift Keying Object
RH_ASK rf_driver;
// Initialize ASK Object
rf_driver.init();
const char *msg = "Hello World";
rf_driver.send((uint8_t *)msg, strlen(msg));
rf_driver.waitPacketSent();
for the receiver:
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK rf_driver;
rf_driver.init();
// Setup Serial Monitor
// Set buffer to size of expected message
uint8_t buf[11];
uint8_t buflen = sizeof(buf);
// Check if received packet is correct size
if (rf_driver.recv(buf, &buflen))
// Message received with valid checksum
Serial.print("Message Received: ");
Serial.println((char*)buf);
but i don't see anything in the serial monitor, what can be the problem? Thanks
