Hey,
I have been trying to generate a 31khz variable duty cycle pwm on atmega8. So far I have been able to generate 7 different frequency pwm with Fast pwm and 16mhz external crystal.
But I cant seem to generate 31khz variable duty cycle one.
I can use ctc mode but its toogle only.
Any help will be appreciated
Post the code, using code tags, and explain the problem with it.
pinMode(11, OUTPUT);
TCCR2=0x6A; //01101010 in hex
OCR2=0x80; //128 in hex
This gives me a 7.8khz 50% pwm on pin 11. What I am trying to achieve a 31khz pwm with variable duty cycle.
I am using minicore at here for compilation for atmega8
The clock select bits you have chosen for TCCR2 divide the system clock by 8. Choose TCCR2= 0x68 to divide by 1, for 62.5 kHz PWM.
For intermediate values you need to use a different TOP than 256, with a decrease in PWM resolution.
system
Closed
September 16, 2021, 10:34pm
#5
