I'm trying to control an old arcade display that uses 4 - 7 segments display, driven by a UCN5833A
Datasheet
I've ran code some I found and it will display randomly but not specific numbers.
I've mapped out the 4 segments to the outputs of the UCN5833A
Digits 1-3 are the score, Digit 4 is a ball counter
Digit 1 uses outputs 2-8 (one hundreds)
Digit 2 uses outputs 10-16 (tens)
Digit 2 uses outputs 18-24 (ones)
Digit 4 uses outputs 26-32
Using the code below in only displays the "D" & "E" segments in all 4 digits.
This seems like it should be pretty straight forward data 0 for off 1 for on.
Thanks for any input.
const int dataPin = 5;
const int clockPin = 4;
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
shiftOut(dataPin, clockPin, MSBFIRST, '01100000011000000110000001100000');
delay (500);
}//end loop
