328ProMini x2 code issues
Ciao all,
I am trying to add debouncing to my code which works accept for the button presses send multiple chars. when depressed when it should be only one per press instance. I think I have some redundancy here and some just plain messed up code. I suppose this might also be the reason I can com. between Ards, but, not with XBs between. :~
Any help is appreciated.
Remote
const int buttonPin = 7;   // Switch connected to digital pin 3
const int buttonPin1 = 8;   // Switch connected to digital pin 4
const int ledPin = 11;   // Switch connected to digital pin 3
const int ledPin1 = 12;   // Switch connected to digital pin 4
char up = ' pu ';  // ascii motor up
char down = ' pd ';  // ascii motor down
int buttonState = 0; // variable for reading pushbutton1 status
int buttonState1 = 0; // variable for reading pushbutton2 status
int lastButtonState = LOW;   // the previous reading from the input pin
int lastButtonState1 = LOW;   // the previous reading from the input pin
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
long lastDebounceTime1 = 0;  // the last time the output pin was toggled
long debounceDelay1 = 50;    // the debounce time; increase if the output flickers
char nextChar;
  Serial.begin(9600);   // Initialize the Serial port:
  pinMode(buttonPin, INPUT);    // sets digital pin as input to read switch
  pinMode(buttonPin1, INPUT);    // sets digital pin as input to read switch
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin1, OUTPUT);
       buttonState = digitalRead(buttonPin);   // read the state of the pushbutton value:
       buttonState1 = digitalRead(buttonPin1);   // read the state of the pushbutton value:
       int reading = digitalRead(buttonPin);  // check to see if you just pressed the button
  if (reading != lastButtonState)
    lastDebounceTime = millis();  // reset the debouncing timer
       if ((millis() - lastDebounceTime) > debounceDelay)
    buttonState = reading;
  if (buttonState == HIGH)   // check if the button is pressed
         Serial.print("1u");
         digitalWrite(ledPin, buttonState);
         delay(100);
     else if (buttonState1 == HIGH)   // check if the button is pressed
         Serial.print("1d");
         digitalWrite(ledPin1, buttonState1);
         delay(100);
  if (Serial.available())
       nextChar = Serial.read();  // read one character
       if (nextChar == up)  // check for 'Up'
       else if (nextChar == down)  // check for 'Dn'
Base
#include <Stepper.h>
#define motorSteps 200     // change this depending on the number of
                           // steps per revolution of your motor
#define motorPin1 9
#define motorPin2 10
#define motorPin3 11
#define motorPin4 12
const int ledPin = 5;   // Switch connected to digital pin 3
const int ledPin1 = 6;   // Switch connected to digital pin 4
int inByte = 0;         // incoming serial byte
char up = '1u';  // ascii motor up
char down = '1d';  // ascii motor down
int myStepperState;  // variables will change:
char nextChar;
// initialize of the Stepper library:
Stepper myStepper(motorSteps, motorPin1,motorPin2,motorPin3,motorPin4);
   myStepper.setSpeed(80);   // set the motor speed at 60 RPMS:
         myStepper.step(300);  // Step forward 300 steps:
         Serial.print(" pu ");
         digitalWrite(ledPin, HIGH);
         delay(100);
         digitalWrite(ledPin, LOW);
         myStepper.step(-300);  // Step backward 100 steps:
         Serial.print(" pd ");
         digitalWrite(ledPin1, HIGH);
         delay(100);
         digitalWrite(ledPin1, LOW);
     int inByte = Serial.read();  // read just one character
     if (inByte == up)  // check for '1u'
     else if (inByte == down)  // check for '1d'
Anybody have any ideas?
Graynomad, what do you think?
Anybody? Bueller...Bueller.
The correct data-type is "unsigned long" not "long".
Would you prefer a ready-to-use solution or would you prefer to learn how to de-bounce a button?
Thank you. I have been trying to "get it" from a book, but, debouncing is eluding me. Especially with my code already working. Adding it is cumbersome.
So, I think learning the when's, why's and how's is best.
I've used two techniques both of which seem to work well...
  1. Fire on click ... A click is immediately handled and a timer is started. While the timer runs, the digital input is ignored. This method works well if you are only interested in clicks. This method does not work well for handling "holds" or releases.
  2. State machine ... There are three states: up, down, limbo. The digital input is read in setup to determine the initial state (up or down; we'll start in up). When the digital input changes, we enter the limbo state and start a timer. If the digital input returns to the previous value, we return the previous state (up) and stop the timer. If the timer expires, we transition to the new state (down). Going the other direction works the same way. This method works well for especially "noisy" digital inputs (buttons usually aren't). However, this method really requires object-oriented programming.
It's about bedtime. I'll try to post some code for #1 tomorrow. Hopefully someone else will post their code between now and then to get you started.
Morning @Coding Badly,
I think the FoC would do fine in my code.
It simply says State is changed and a small delay executed upon button press, no? This keeps the small button fluctuations created by a human finger (flutter) from being used in the code. Right?
But, State machine is not clear to me as to why it is so different.
And how would I incorporate either into my code? Would I need to rework the whole thing or some or very little?
Thx.
Days later Coding Badly has time to reply...
Utoto: It simply says State is changed and a small delay executed upon button press, no?
Yes. Ideally, the delay should be implemented in the "Blink Without Delay" fashion so your Sketch is not blocked. But, in the simplest case, you just put a delay after detecting the button click.
Right. (only the fluctuations are usually from "bouncy" switch contacts not from a finger)
It ensures both "click" and "release" can be cleanly detected. You would use the State machine if you need to handle both directions.
I'll make a series of code examples that hopefully will illustrate how it works. You can decide if you need more help or if you can rework your Sketch on your own.
Fire on click WITH NO DEBOUNCE. This shows the how to detect a digital input state change and execute code for a HIGH to LOW change (using pullup resistor)...
const uint8_t PushbuttonPin = 4;
const uint8_t LEDPin = 3;
int PreviousState;
void setup( void )
  // While the following is technically not necessary but it clearly conveys our intention.
  pinMode( PushbuttonPin, INPUT );
  // Because I'm too lazy to dig out a resistor, I'll use the internal pullup resistor.
  digitalWrite( PushbuttonPin, HIGH );
  // The LED is solely to turn this into a self contained example.
  pinMode( LEDPin, OUTPUT );
  // Read the initial state of the digital input
  PreviousState = digitalRead( PushbuttonPin );
void loop( void )
  int CurrentState;
  boolean PushbuttonClicked;
  // Read the current state
  CurrentState = digitalRead( PushbuttonPin );
  // Assume the pushbutton was not clicked
  PushbuttonClicked = false;
  // Did the digital input change from the last time we read it
  if ( CurrentState != PreviousState )
    // Because we're using a pullup, LOW means the pushbutton is pressed
    if ( CurrentState == LOW )
      // The input state changed and the pushbutton is pressed which can only mean the pushbutton was just clicked
      PushbuttonClicked = true;
    // The current state of the digital input becomes the previous state
    PreviousState = CurrentState;
  if ( PushbuttonClicked )
    // Handle the click here.
    digitalWrite( LEDPin, ! digitalRead( LEDPin ) );
Fire on click WITH DEBOUNCE. To see the effect, change DebounceMillis to 1000...
static const uint8_t PushbuttonPin = 4;
static const uint8_t LEDPin = 3;
int PreviousState;
unsigned long PreviousMillis;
static const unsigned long DebounceMillis = 50;
void setup( void )
  // Force the time condition to be true for the first button click
  PreviousMillis = 0x80000000;
void loop( void )
  int CurrentState;
  unsigned long CurrentMillis;
  // Record the current time
  CurrentMillis = millis();
  if ( (CurrentState != PreviousState) && (CurrentMillis - PreviousMillis >= DebounceMillis) )
      // Record the time of the click.  Ignore changes until the debounce time has elapsed.
      PreviousMillis = millis();
Fire on click with debounce restructure as a class. Simply add more CodingBadlyDebouncer instances for more buttons.
class CodingBadlyDebouncer
public:
  void begin( uint8_t pin, bool useInternalPullup );
  void update( void );
  bool wasClicked( void )
    return( _wasClicked );
private:
  uint8_t _pin;
  bool _pullup;
  bool _previousState;
  unsigned long _previousMillis;
  bool _wasClicked;
void CodingBadlyDebouncer::begin( uint8_t pin, bool useInternalPullup )
  _pin = pin;
  pinMode( pin, INPUT );
  // If requested, enabled the internal pullup
  if ( useInternalPullup )
    digitalWrite( pin, HIGH );
    _pullup = true;
    _pullup = false;
  // Read the initial state of the digital input.  The "!= _pullup" condition makes _previousState HIGH if the button is down
  _previousState = digitalRead( pin ) != _pullup;
  _previousMillis = 0x80000000;
  // Ensure no misfires
  _wasClicked = false;
void CodingBadlyDebouncer::update( void )
  int CurrentState;
  // Read the current state.  The "!= _pullup" condition makes CurrentState HIGH if the button is down
  CurrentState = digitalRead( _pin ) != _pullup;
  // Did the digital input change from the last time we read it and the debounce time has elapsed
  if ( (CurrentState != _previousState) && (CurrentMillis - _previousMillis >= DebounceMillis) )
    // The "!= _pullup" condition above makes it so CurrentState is HIGH when the button is pressed
    if ( CurrentState == HIGH )
      _wasClicked = true;
      _previousMillis = millis();
    _previousState = CurrentState;
CodingBadlyDebouncer pushbutton;
void setup( void )
  pushbutton.begin( PushbuttonPin, true );
void loop( void )
  pushbutton.update();
  if ( pushbutton.wasClicked() )
I don’t think these lines do what you expect:
The type ‘char’ holds a single character in a single byte. If I recall correctly from my years of C and C++ programming, the construct ’ pu ’ is a four byte constant. When you store a four-byte value in a one-byte variable it gets truncated. I think both will end up being ’ ’ (space). If you want named character strings you probably want something like:
char up[] = " pu ";  // ascii motor up
char down[] = " pd ";  // ascii motor down
 or
#define up " pu "
#define down " pd "
