32mHz ARDUINO PROJECTS.. ATMega328P etc...
Ha ha, thanks all !!
westFw, I have been thinking about the arm stuff, even to the point of getting several stm32f1 boards after the (now very long) topic was started on here.
for me its not a simple jump, I write in C AND assembler, the task of learning the 32bit assembly and all the register manupulation didnt suit me too well as I am just about coping with 8 bit !!
Crossroads, it is mainly for multicolour VGA purposes, I really need the speed !!
for me its not a simple jump [to ARM]
This online class has just started, and I highly recommend it. If you already have experience programming AVRs in C and assembly, you'll be well ahead of "median" background, but it's STILL a good introduction to ARM programming...
https://www.edx.org/course/embedded-systems-shape-world-utaustinx-ut-6-02x
Cheers WestFw, I think I would need to sign up as I cant see much on that page/link
Link with no-login-required info (also, previous post "fixed"): https://www.edx.org/course/embedded-systems-shape-world-utaustinx-ut-6-02x
Interesting, I had found I could run at around 24 MHz (note the M) with a crystal but not faster. Now I am motivated to try faster clock inputs, excluding crystals.
AWOL: I very much doubt that ;)
Annoyingly, the proper capitalization of 1,000 is k but 1,000,000 is M.
[quote author=Nick Gammon link=msg=2057629 date=1422077185] Interesting, I had found I could run at around 24 MHz (note the M) with a crystal but not faster. Now I am motivated to try faster clock inputs, excluding crystals. [/quote]
Yes Nick, I got that far too, but then realised I had to switch to a TTL clock gen for higher speeds as the micro wasnt able to drive the crystal or something, I cant remember the full reason but thats in the past now
@mcnobby,
I have looked for the crystal that you are using but, have not found a cheap way to buy a crystal just for playing around. However, I ordered a breakout board last night that may prove interesting! Adafruit Si5351A Clock Generator Breakout Board - 8KHz to 160MHz http://www.adafruit.com/product/2045
The breakout board is not practical for a finished product but, it will allow me to find out how fast an Arduino can go. :)
cyclegadget:
I have been using THESE. they are about £0.19p each in qty of 10, but they are surface mount which can be a problem if you just use standard mount
I did find some surplus stock standard mount ones on ebay, bought a load for testing/playing very cheap, I have had a look but cant find them anymore
Neat stuff. Sounds like a good omen for trying to make the ATTiny's that are normally spec'ed only to 12mhz run at 16mhz like a normal Arduino.
Which ATTiny's are spec'ed at 12MHz? The t84 and t85 are both rated up to 20MHz...
Hi. Are you still here? I wonder how you can remove the crystal and replace it with an external clock without changing the fuse bits before. It seem a chicken and egg problem. Have you burned the bootloader with the fuse and then changed the circuit?
It is absolutely no problem, but once if the chip is set to use external clock or crystal, it (clock signal generally) must be present otherwise the MCU will not start. So, just replace the crystal. Of course, the bootloader have to be changed for exact frequency. However I'm not recommending to use 32MHz. I have some experience with overclocking on ATmega1284P. Some features doesn't work at higher frequency as 25MHz, e.g. prescaler for ADC. I had the best results with 24MHz. The MCU works reliably at 24MHz, no getting a heat and all features seem to work. ...but 328P can be different story!
Hi All
I am currently overclocking an ATTiny13A to about 16MHz on INTERNAL resonator, just by setting it to 9.6MHz internal resonator, then writing OSCCAL to 255 (I think only 7 bits are actually used), this then doubles the 9.6MHz internal clock approximately. If you dont need to worry about exact timing then this is great fudge.
I use this for receiving and decoding an 800KBPS data stream and driving a servo from the data and it works a treat as I continually sync on the start/high transition of each bit and sample in the middle, so probably even 1MHz either way would still work
The ATTiny13A does not have pins for a standard xtal, and can only be driven externally by a TTL Clock oscillator, so I chose the method above for cost and simplicity
This overclock can also be done on an ATTiny45/85, so I believe (although you can use a standard xtal with those)
Bob
I have done many ATMega projects using 32MHz TTL clock oscillators and not found any heat problems, in fact not noticed and heat given off at all. I cant verify that any new microcontrollers still work as well since Microchip took over the AVR range and I believe they opened a new fabrication plant in Scandinavia and reduced some of the specs on devices from 20MHz down to 16MHz.. early 2017 from my memory anyway !
mcnobby: ... reduced some of the specs on devices from 20MHz down to 16MHz..
Which ones specifically? I checked the 328P and my favorite 1284P. Both are 20MHz and additional about 40 mega and tiny MCUs.
Which mega with 32MHz did you use? Try to check the ADC. I doubt it will work reliably - sample rate and the highest resolution. I tested 1284P. It seems to work reliably just up to 25MHz.
Hi, I just saw some notification last year, I cant remember the detail now but I think it had something to do with the maximum frequency using a standard xtal (maybe) and with my overclocking I wasnt using ADC, just bit blasting I was using ATTiny13A/85 and ATMega328/1284 with 32Mhz clock oscillator I think I found that you can use up to 24Mhz standard xtals with some of the ATMegas
Hi! I think, they use same fabrication process for all AVRs, so it is not as surprising that it works with 32MHz clock. You motivate me to test it at least on spare time. It is some time ago, but I think Krupski had presented here ATmega2560 at 32MHz. This is only 16MHz MCU according the datasheet.
BTW: The link "www.smartshow.lighting" below your karma is incorrect.
I also bought some 40MHz clock oscillators, but never got round to testing them :)
mcnobby:
I have been using 32mHz crystal oscillators on my projects for some time now without any crashes or ANY noticable heat from the processor.
I run my AVR boards at 22.1184 all the way to 29.952 without any problems. By the way, you don’t need an OSCILLATOR to do this, just set your crystal drive from “low power” to “full swing” and it works fine.
