32x8 led matrix wrong direction
I have issue with direction of my sliding text. I want to do it horizontally but it goes vertically.
Can anybody tell me why? My board is “MAX7219 Dot Matrix”
Here you have code:
//We always have to include the library
#include "LedControlMS.h"
Now we need a LedControl to work with.
***** These pin numbers will probably not work with your hardware *****
pin 12 is connected to the DataIn
pin 11 is connected to the CLK
pin 10 is connected to LOAD
We have only a single MAX72XX.
#define NBR_MTX 4
LedControl lc=LedControl(12,11,10, NBR_MTX);
/* we always wait a bit between updates of the display */
String scrollString= "MAKESPACE MADRID    ";
int stringLength=scrollString.length();
char ch0, ch1, ch2, ch3;
int nextCharIndex=0;
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  Serial.begin (9600);
  Serial.println("Setup");
  Serial.println(scrollString);
  Serial.println(stringLength);
  for (int i=0; i< NBR_MTX; i++){
    lc.shutdown(i,false);
  /* Set the brightness to a low value */
    lc.setIntensity(i,1);
  /* and clear the display */
    lc.clearDisplay(i);
  delay(100);
  lc.clearAll();
  ch0= scrollString[0];
  ch1= scrollString[1];
  ch2= scrollString[2];
  ch3= scrollString[3];
  nextCharIndex=4;
void loop(){
  lc.displayChar(0, lc.getCharArrayPosition(ch0));
  lc.displayChar(1, lc.getCharArrayPosition(ch1));
  lc.displayChar(2, lc.getCharArrayPosition(ch2));
  lc.displayChar(3, lc.getCharArrayPosition(ch3));
  ch0=ch1;
  ch1=ch2;
  ch2=ch3;
  ch3=scrollString[nextCharIndex++];
  if (nextCharIndex>=stringLength) nextCharIndex=0;
  delay(300);
  lc.clearAll();
  delay(25);
Jabbadabbadahaht: My board is "MAX7219 Dot Matrix"
Link?
Here you go if you ment that Aliexpress module
You neglected to read the reviews on how to make the display work.
These are FC-16 modules. You can make then work with LedControl by changing the definition of the font and rearranging the way the code scrolls. The problem is that there are a number of ways to wire up these matrices and LedControl assumes one way.
Alternatively you can use the libraries mentioned in the reviews:
Work fine with MD_Parola and MD_Max72xx library if you use #define USE_FC16_HW
Link to the libraries in my signature footer. Please make sure you read the MD_MAX72xx documentation on how to configure the library as described and note that the lowest modules number is on the right (ie, the 'in' side is on the right).
