33 iot BLE not visible to devices
Good Morning
I followed the BLE tutorial on the official docs.arduino.cc, but the board isn`t visible at all therefore cannot be paried.
I did run through the process of firmware update for the nina ble module without effect.
When i open serial it does say BLE LED Peripherial
Is there anything else that needs doing?
#include <ArduinoBLE.h>
long previousMillis = 0;
int interval = 0;
int ledState = LOW;
BLEService ledService("180A"); // BLE LED Service
// BLE LED Switch Characteristic - custom 128-bit UUID, read and writable by central
BLEByteCharacteristic switchCharacteristic("2A57", BLERead | BLEWrite);
  while (!Serial);
  // set built in LED pin to output mode
  pinMode(LED_BUILTIN, OUTPUT);
  // begin initialization
  if (!BLE.begin()) {
    Serial.println("starting Bluetooth® Low Energy failed!");
    while (1);
  // set advertised local name and service UUID:
  BLE.setLocalName("Nano 33 IoT");
  BLE.setAdvertisedService(ledService);
  // add the characteristic to the service
  ledService.addCharacteristic(switchCharacteristic);
  // add service
  BLE.addService(ledService);
  // set the initial value for the characteristic:
  switchCharacteristic.writeValue(0);
  // start advertising
  BLE.advertise();
  Serial.println("BLE LED Peripheral");
  // listen for BLE peripherals to connect:
  BLEDevice central = BLE.central();
  // if a central is connected to peripheral:
  if (central) {
    Serial.print("Connected to central: ");
    // print the central's MAC address:
    Serial.println(central.address());
    // while the central is still connected to peripheral:
    while (central.connected()) {
      // if the remote device wrote to the characteristic,
      // use the value to control the LED:
      if (switchCharacteristic.written()) {
        switch (switchCharacteristic.value()) {   // any value other than 0
          case 01:
            Serial.println("LED on");
            digitalWrite(LED_BUILTIN, HIGH);            // will turn the LED on
          case 02:
              Serial.println("LED fast blink");
              digitalWrite(LED_BUILTIN, LOW);         // will turn the LED off
          case 03:
            Serial.println("LED slow blink");
          default:
            Serial.println(F("LED off"));
    // when the central disconnects, print it out:
    Serial.print(F("Disconnected from central: "));
So, what appear to happen, is that the BLE can only advertise when IDE is open. I prooved this in my case on 33 IOT and Portenta Machine control. Once you shut the IDE and restart the board, the board is no longer discoverable.
Any thoughts?
