ok, so you are using the RCswitch library with no modifications and have the data pin of the module connected to pin 2 on the Arduino?
You could connect an LED to this as well that will flicker when data is being received by the module. To check this with the Arduino, try a little sketch like this:
oh, and make sure that you have the ground on the transmitter connected to the ground on the arduino. Otherwise, a high or low may not be valid voltage levels.
I am using the example code with no modifications. I did play around with pins other than pin 0 (pin 2) just for fun.
If I run this code (which I found online)
DigitalReadSerial
Reads a digital input on pin 2, prints the result to the serial monitor
This example code is in the public domain.
// digital pin 2 has a pushbutton attached to it. Give it a name:
int pushButton = 2;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// make the pushbutton's pin an input:
pinMode(pushButton, INPUT);
// the loop routine runs over and over again forever:
// read the input pin:
int buttonState = digitalRead(pushButton);
// print out the state of the button:
Serial.println(buttonState);
delay(1); // delay in between reads for stability
I see just
0
0
0
0
0
0
many times.
then when I hook up the remote and press a button I do see it change, like
1
0
1
1
1
0
I suspect that's because it is generally not a good idea to do a serial print in the middle of an interrupt. So, the pin is working and the interrupt is working. Try my code with the remote connected. It is similar to the code you already tried, but uses an interrupt instead. It may freeze up, but if you get some stuff flowing, at least you know the remote is able to trigger an interrupt.
I knew what you meant. It freezes completely. Only a reset brings things back to life.
I have had this happen when I didn't connect grounds together and I have had it happen when I have put serial commands inside of interrupts (though it doesn't always freeze up.) What is the floatingpin thing you have read about?
The Dout voltage from the transmitter could be too high or too low. It should be held high when not transmitting. Do you have a multimeter to check it?
int forwardPin = 12;
pinMode(forwardPin, INPUT);
digitalWrite(forwardPin, HIGH); // Turn on the pullup resistor.
int forwardState = digitalRead(forwardPin);
if (forwardState == HIGH)
Serial.print("1");
Serial.print("0");
When I run this I get a nice stream of 1s. No random variations. When I connect pin 12 to the signal pin, they change to 0s. Then when I press the button for light on, I get this.
000000011010000000001101101000000001101000000000001101000000001100110100000000110100000000000110100000000110110110000000011010000000000011010000000011011010000000001101000000
However, if I go run that in the binary RCSDemo. Nothing happens.
Example for different sending methods
http://code.google.com/p/rc-switch/
Need help? http://forum.ardumote.com
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(10);
// Optional set pulse length.
// mySwitch.setPulseLength(320);
// Optional set protocol (default is 1, will work for most outlets)
// mySwitch.setProtocol(2);
// Optional set number of transmission repetitions.
// mySwitch.setRepeatTransmit(15);
/* Same switch as above, but using binary code */
mySwitch.send("000000011010000000001101101000000001101000000000001101000000001100110100000000110100000000000110100000000110110110000000011010000000000011010000000011011010000000001101000000");
delay(20000);
sure, in the interrupt routine, you could just do this instead of serial.print:
byte value;
value = digitalRead(2);
digitalWrite(3,value);
There may be an error with digitalWrite taking value instead of HIGH or LOW. If so, try:
int value;
instead of byte.
That should relay whatever it reads on pin 2 out to pin 3. There will be a delay of course, but as long as the delay is consistent, the transmitter shouldn't care.
If you get a chance to measure that voltage, let me know. We may have to do something in-between to get it all nice and happy.
As a last resort, you could try to figure out which pins on the PT2262 that the buttons are connected to and which pins the address are set for from the circuit. That will tell you what commands are what instead of trying to read the remote output.
You could always go with your original plan to hook the buttons up directly on the remote and control it that way, but I think getting this sorted out will be more useful to you in the long run. I won't be able to mess with it much this weekend, but if you haven't figured it out by Monday, I will grab one of my remote outlets and attempt it myself to see if there are any gotchas.
Well I got home tonight and figured I'd look up all the values I've tried to use so far and come up with something. It took a couple hours, but It's a nice course in simple programming!
int inpin = 2; // makes the input pin pin 2
int outpin = 3; // makes the output pin pin 3
int val = 0; // sets the initial variable to 0
Serial.begin(9600); // initialize serial communication at 9600 bits per second:
pinMode(inpin, INPUT); // makes inpin the input pin
pinMode(outpin, OUTPUT); // makes outpin the output pin
// the loop runs over and over forever
int inpinState = digitalRead(inpin); //reads the state of the input pin
digitalWrite(outpin, inpinState); //writes the state of the input pin on the output pin
Serial.println(inpinState); //displays the value of the input pin on the screen
delay(0); // delay in between reads for testing
Results:
If I physically connect the transmitters signal line to the button boards signal line the remote works. I can control the light.
If I run it though the arduino with the above code, I get nothing. I can see the binary change happening as I push the button, but the lights don't respond.
What if there is a speed mismatch between what the arduino can process and what the button board and transmitter use? So the binary doesnt get though right? Like watching my arudino set at 9600 baud with a serial monitor set at 1200 baud?
Could it be an analog signal or a sign wave? I dont know. Scrapping for ideas.
I just had to get rid of the serialprint line. I guess the extra little clock cycle that it took to print that line made the receiver not respond.
Now I just need to capture some codes. I guess I have two ways to do this.
capture the codes using serialprint and copy paste into notepad and tinker until it works. Hardcoded codes do sound nice.
put some code in the setup section that will say "press the light toggle switch" then capture that code into a variable called lighttoggle. Then prompt the user "press the fan on button" then capture that code into a variable called fanon.
I know how to use serialprint and I know how to create variables now. What I dont know is how to make it prompt, wait for input, then know when to move on to the next section.
Plus under option 2 I would have to store variables that were, 8, 16, however many bytes long and not just an instantaneous state change.
You just print the prompt out. Then you use this (in your loop):
if(Serial.available()){ //Someone entered something in the serial display
byte c = Serial.read();
if(c > 0){ //We have a non-null value, so do something with it
switch(c){
case 'm': //'m' was sent
//run some code meant for 'm'
break; //always break after doing the command unless you want it to "fall through"
case 'n': //'n' was sent...
//do some code for 'n'
//etc...
If you have multiple steps, like multiple prompts, keep a state machine (keep a count of steps) so it knows what step it is at.
In your case, it might make more sense to increment the steps based on the interrupt. That way your code knows when the button was actually pressed.
byte state = 0;
byte light_toggle;
byte fan_toggle;
#define maxStates 6 //if there will be six steps total
void loop(){
switch(state){
case 0:
Serial.print("Press the light toggle switch");
break:
case 1:
light_toggle = value;
Serial.print("Light toggle command is: ");
Serial.println(light_toggle, DEC);
state++ //we have to increment the state here since no interrupt
case 2:
Serial.print("Press the fan toggle switch")
case 4:
fan_toggle = value;
Serial.print("Fan toggle command is: ");
Serial.println(fan_toggle, DEC);
//etc... for all states
void interrupt(){
state = state++ //increments the state counter
//....do normal interrupt code here
if(state > maxStates) state = 0; //reset the state counter
If your value is 8 bits use byte value in your declaration, if it will be 16, use unsinged int value
There may be some minor errors in there. I always make stupid mistakes when writing code and only catch them when I go to compile. So, you may have to mess it, of course. It's just an example.
BTW, your address part of the command will (likely) always be the same for a particular device. So you really only need to capture that part once, then just store the command part for each button.
I am very interested in home automation myself. I even have all the X0 goodies including all the software that lets you program intelligent control and control from the web, but I am currently only renting a house so I am limited in what I can do. I have always thought it would be nice to tie all the various pieces together at some point. Maybe I should start playing with it a little so I have all the chunks ready when I move on.
I tend to stay at the girlfriends over the weekend, so something like an 'away' macro that turned off all the lights, set the thermostat down, ocassionally turned on lights to make it appear that I was home, set the security system, etc.. would be nice. Also checking on the cats and being able to feed and water them remotely would be nice. Hmm... I may have to start playing again.
Oh yeah. I love this stuff. I dreamed of working on one for awhile. You need the arduino automatic cat feeder and sandbox scrapper with a little robot that will collect the doo doo and run it to the trash for you I swear possibilities are only limited by a persons imagination and technical ablilty.
I tried this:
byte state = 0; //sets bytes vale to 0???
byte light_toggle; // creates byte light_toggle
byte value; //creates byte value to display value
#define maxStates 6 //if there will be six steps total (I'm not sure how this works. There are 2 states on and off?)
switch(state){ //like an if statement
case 0:
case 1:
light_toggle = value; //what is this doing? It's setting light_toggle = value.
state++; //we have to increment the state here since no interrupt
And it prints "Press the light toggle switch" over and over again.
I'm not sure how #define maxStates 6 works. Why do you need to know this? Nothing ever references maxStates?
I think I need to somehow put the code together so that each state where we read a byte has it's own "if(c > 0)" section. I'm not even close to understanding how that piece of code works yet. It should just ignore all 0s so if it sees 0 then 0 then 0 then 0 then 0 it does nothing. But if a 1 pops up it says "hey listen up write this down" for 8 bits and call that bit light_toggle and file it away.
Just for fun I also tried playing with it with
byte onbyte = digitalRead(inpinState) | (digitalRead(inpinState)<<1) | (digitalRead(inpinState)<<2) | (digitalRead(inpinState)<<3) | (digitalRead(inpinState)<<4) | (digitalRead(inpinState)<<5) | (digitalRead(inpinState)<<6) | (digitalRead(inpinState)<<7);
added
Serial.print(onbyte); //displays the value of the input pin on the screen
//delay(0); // delay in between reads for testing
It was repeating over and over again because the "state" is always going to be zero at least until an interrupt comes in. Hmm... sounds like we need another flag to tell whether it is the first time running so loop doesn't trigger every time. See, I told you I make stupid mistakes the first time around. lol
maxStates is the total number of states (no of prompts + number of entries.) So if there are three buttons to push, you have six states. Otherwise it would just keep counting forever. We want it to go back to the beginning when it has counts past the last state. I was doing that here:
