360 degree coming things sensor
Hi
I want to build a car that can move away from coming things , so I need some sensor to find anything coming In 360 degree , I'm thinking to put 4 ultrasound sensors but I think there is will be some interference and bad sensing !
I need your ideas professional People.
FDosais:
Hi
If you program them to operate in a sequence so only one is active at a time, might work. But you must consider detecting something coming at 45 degrees, so two sensors detect the same movement. Or two things are coming from opposite directions. What then?
I would not class all that as interference, but as opportunities for you to design the system to handle.
Paul
Check the detection angle of your sensors. It's probably less than 45°, expect something like 30°, meaning you have blind spots with just four sensors. At such an angle you'd need more like eight sensors.
it think you should check here for more professional solution
u will just need servo and 1 ultrasound sensor. You can use 2 if it is inefficient for you
