360 degree servo code trouble
Not going to lie, I’m not very good with code at all and apparently neither is my teacher because I cannot get any help on this project. I am trying to create a code that has an IRremote control a 360 degree servo motor for a project. I believe it has something to do with the decode results, but i have no idea what to do or what to change. Please help. Thank you.
Code:
#include <IRremote.h>
#include <Servo.h>
#define MY_PROTOCOL NEC
#define RIGHT_ARROW 0xfd50af //Move several clockwise
#define LEFT_ARROW 0xfd10ef //Move servo counterclockwise
#define SELECT_BUTTON 0xfd906f //Center the servo
#define UP_ARROW 0xfda05f
#define DOWN_ARROW 0xfdb04f
#define BUTTON_0 0xfd30cf //Pushing buttons 0-9 moves to fixed positions
#define BUTTON_1 0xfd08f7
#define BUTTON_2 0xfd8877
#define BUTTON_3 0xfd48b7
#define BUTTON_4 0xfd28d7
#define BUTTON_5 0xfda857
#define BUTTON_6 0xfd6897
#define BUTTON_7 0xfd18e7
#define BUTTON_8 0xfd9867
#define BUTTON_9 0xfd58a7
IRrecv My_Receiver(11);//Receive on pin 11
decode_results results; //define variable results to save the result of infrared
Servo My_Servo; // create servo object to control a servo
int pos; // variable to store the servo position
int Speed; // Number of degrees to move each time a left/right button is pressed
long Previous; // Stores previous code to handle NEC repeat codes
My_Servo.attach(9); // attaches the servo on pin 9 to the servo object
pos = 90; // start at midpoint 90 degrees
Speed = 3; // servo moves 3 degrees each time left/right is pushed
My_Servo.write(pos); // Set initial position
My_Receiver.enableIRIn(); // Start the receiver
if (IRrecv.decode(&results)) { {
decode_results.decode();
if(decode_results.decode_type==MY_PROTOCOL) {
if(decode_results.value==0xFFFFFFFF)
decode_results.value=Previous;
switch(decode_results.value) {
case LEFT_ARROW: pos=min(180,pos+Speed); break;
case RIGHT_ARROW: pos=max(0,pos-Speed); break;
case SELECT_BUTTON: pos=90; break;
case UP_ARROW: Speed=min(10, Speed+1); break;
case DOWN_ARROW: Speed=max(1, Speed-1); break;
case BUTTON_0: pos=090; break;
case BUTTON_1: pos=1
00; break;
case BUTTON_2: pos=290; break;
case BUTTON_3: pos=3
90; break;
case BUTTON_4: pos=490; break;
case BUTTON_5: pos=5
90; break;
case BUTTON_6: pos=690; break;
case BUTTON_7: pos=7
90; break;
case BUTTON_8: pos=890; break;
case BUTTON_9: pos=9
0; break;
My_Servo.write(pos); // tell servo to go to position in variable ‘pos’
Previous=decode_results.value;
My_Receiver.resume();
Errors:
In function ‘void loop()’:
40: error: expected primary-expression before ‘.’ token
41: error: expected unqualified-id before ‘.’ token
42: error: expected primary-expression before ‘.’ token
43: error: expected primary-expression before ‘.’ token
44: error: expected unqualified-id before ‘.’ token
45: error: expected primary-expression before ‘.’ token
63: error: expected primary-expression before ‘.’ token
exit status 1
You have not created an object called IRrecv. You can only call methods on instances that you have created. You DID create an instance of the appropriate class, called My_Receiver. Use that instance name.
You created an instance of the decode_results struct, but you did not call it decode_results. Use the name of the instance you created.
Look at the IRrecvDemo example.
