360 degree Servo keeps running
I have a sketch that calls for dc motors to run one way, then delay, then run another way, then call the servo to spin. The problem Im having is that the servo is spinning constantly from the beginning of the sketch non stop. It does seem to change directions when the pos variable is logged, which is when the servo is supposed to run and it does seem to run in the correct directions during that time. But then it just keeps going "straight" until the runServo method is called again.
Is it because its a 360 degree servo or because I have to stop the servo explicitly?
#include <Servo.h>
#include <AFMotor.h>
AF_DCMotor motor1(1);
AF_DCMotor motor2(4);
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
    myservo.attach(9);  // attaches the servo on pin 9 to the servo object
    // Start up serial connection
    Serial.begin(9600); // baud rate
    Serial.flush();
void runServo(){
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    Serial.println(pos);
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
void loop(){
  delay(2000);
  // SPIN AROUND
  motor1.setSpeed(200);
  motor1.run(FORWARD);
  motor2.setSpeed(200);
  motor2.run(FORWARD);
  //STOP FOR A WHILE
  delay(5000);
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  //RUN FORWARD
  motor2.run(BACKWARD);
  //STOP FOR A WHILE
  delay(5000);
  runServo();
If it is a "continuous servo" you will need to find, experimentally, the number that will stop the servo. The number will be around 1500 microseconds or 90 degrees.
