360 degree Servo question
I'm modifying the code for 180 degree Servos and need to know what no movement is for the myservo.write function. I've tried 180 but it doesn't work. Any ideas welcome.
Radiodress,
the Servo library accepts only degree values from 0 to 180 and doesn't care how much that is in reality. There are no bug-eyes sticking out of your Arduino to check if your servo is really doing 180 degree if you tell it so. To avoid any confusion, better use microseconds (usually between 1000 and 2000, but can be a bit lower and high depending on the servo) as parameter of the write function (or use writeMicroseconds instead).
Korman
