Hey! I am using 360 servos in my project. I am having an issue as my servo do not hold their position ( as 360 servos are not positional control). Let say I used 360 servo and now it is at a specific position but due to load on it when motor will be at rest ( 0 velocity), I will not hold at that position but i want to make it stay there. Any soutions?
Hello ammarmazharsatti
As long as the servo is powered and controlled the servo will hold the positie due to the internal loop control.
Actually it is 360 servo as i mentioned, it is velocity controlled.
All you can do is set the speed to zero but it won't hold a position if it has a load on it
So only way can be using a feedback sensor?
Post a picture of the servo used.
Yes but since you can only control speed, it may result in some positional jitter.
or a break.
