38kHz Infrared Receiver for IR remote - are they just IR photo-transistors?
Hello,
I see these 38kHz IR receivers used a lot for projects. For example
https://learn.sparkfun.com/tutorials/ir-control-kit-hookup-guide
You can find them on ebay and Radioshack.
I don't understand why the product description mentions the modulation frequency. I understand there are two frequency elements at work:
  1. IR frequency: well, really it's the wavelength of the actual IR light, which is usually 940nm, and is often not even mentioned product description.
  2. Modulation frequency: I think this is the 38kHz that's often mentioned in the product description.
I don't understand why the IR receiver would have a modulation frequency attribute. Is the TSOP4838's just a photo-transistor that tuned for IR wavelength? When buying these IR receivers, why do they mention the modulation frequency at all? Isn't the modulation/demodulation done on the serial pins of the Arduino? My understanding is that the <IRremote.h> library is what is doing the demodulation, is that incorrect?
Do I need to buy a special IR transmitter that's also sold as "38kHz", or can I just use any old 940nm IR LED? The pictures of the IR transmitters on sparkfun definitely look like just regular old LED's.
I would think that the reason is to act as a filter for all the unmodulated IR light that is present in our environment.
You can use an ordinary IR LED to communicate with the 38 kHz IR receiver module, but for best results the emission wavelength of the transmitting LED should be a close match to the peak reception wavelength of the receiver. What IS critical is that you have to modulate the transmitting LED at two or more frequencies: first at 38 kHz and at the same time, turn the 38 kHz stream to the LED on and off to match whatever data transmission protocol you will implement. The receiver will respond only to light that is modulated at or very close to 38 kHz.
arusr:
A receiver like the TSOP4838 has a bit more magic than that going on inside it. It has automatic gain control; it works in both a dark room or full sunlight. It ignores lights flickering at different frequencies (e.g. fluorescent lights). And still on top of this it reliably detects your signal (your LED) which can either be quite bright or dim. Not at all a simple problem if you were starting with a run of the mill phototransistor.
arusr:
When the IR receiver (TSOP4838) sees six consecutive "blinks" of light at the 38KHz frequency it sets its output pin digital high and keeps it high until the moment that it calculates another blink should have occurred but didn't. The IR library then takes the lengths of those highs and the time between them and translates that into a code. So the IR receiver is expecting everything to occur at 1/38000ths of a second timing divisions, but the IR decoder library is only watching the lengths of the pulses coming from the IR receiver.
arusr:
You can use any old IR LED but the receiver is most sensitive to IR LEDs of the 940nm wavelength. As a corollary to that it will still work with other LED colors but at shorter distances. I suggest you start with a white or red LED for testing so you can actually see the light.
