I am planning to build a 4S LiFePo-Powerbank. LiFePo4 are "selfsafe" in the sense of that they do not catch fire when overcharging or damaging them.
So I explicitly want a LiFePo4 charger/balancer which is something very different
than a Lithium or a lithium-polymer-battery
The batteries will have 6000 mAh per cell. So charge-current is 1A to 3A.
Discharge current is in the same range. This means a rather small batterie-management-system (in short BMS) will do.
So far I have only found this
To me the balancing current of 58 mA seems to be very small.
As far as I undestand balancing it is for equalising the voltages to the (almost) same level.
To protect cells that already reached their "full voltage" a current is bypassing the cell.
If this current is pretty small charging the cells that have not yet reached their final voltage will take a long time.
But maybe I am wrong. If somebody knows how it exactly works
or
If somebody knows a link to a LiFePo4-balancer
I would be very thankful for posting the info / the link
best regards Stefan
