3D printer build
hello I'm building a 3d printer using the uno and teacup firmware.
I found these motors on ebay: Stepper Motor NEMA 17 Bipolar 40mm 64oz.in(45ncm) 4 Lead 1m Cable 3d Printer CNC for sale online | eBay
But what I was wondering is if I could use easy drivers to drive them. I know they only output a max of 750ma and the motors can take 2Amp. Do I really need to run these things at 2amp phase for a 3d printer?
From what I understand the only thing that this effects is the torque strength. Could I get away with easy drivers or should I look for different drivers?
What about. 1amp drivers?
Thanks
Yes - I would expect the 3D printer software to use the full motor torque - assuming you have chosen a motor to match your printer specs.
You need a stepper driver that can mange the full motor current. If the motor requires 2 amps I think a Pololu DRV8825 would be better than the A4988 based BigEasydriver or the Pololu A4988.
Of course if you already have the Easydrivers you could try them and see what happens before buying better drivers.
...R
But doesn't the pololu you mentioned only supply 1.4A
I'm really not basing my design off of any kind of printer, I'm just trying to build on a budget.
I'm just worried that 1.4 is under powered. But I can't seem to really find any drivers that put out more current, without the high price and extreme cooling.
There is a guy "bot hacker" who apparently uses small easy drivers without a problem, but I don't want to order them and not have them work.
As far as eBay goes, is that a smart choice for a buying source? I'm nervous with all these over seas suppliers. The motors I found are from California.
These are the drivers I found:
http://www.ebay.com/itm/5x-Geeetech-Stepper-driver-Pololu-DRV8825-heatsink-for-RAMPS1-4-Sanguinololu/271635231167?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D3b16a7d260db4d5db9d8b72f60a6114c%26pid%3D100033%26rk%3D2%26rkt%3D4%26sd%3D261709461194
It would make the most sense to purchase your drivers in combination with a RAMPS board.
As to whether or not you'll need to use a full 2A for your motors is hard to say; you never have to use full current and it certainly makes sense to cut back to the minimum (the DRV8825 you have allow current adjustment). But NEMA 17 motors of the size you have can be found in jillions of other printers and seem to work just fine.
Worst case scenario, if you're not getting enough torque, you just won't be able to move your printhead as quickly as you'd like.
alltroid:
How do you reconcile these comments? 1.4A is almost twice what an Easydriver can do. I mentioned the DRV8825 because it is more powerful than the A4988.
Of course you can always get more expensive drivers that can handle 3 or 5 amps. They can be controlled just as easily with an Arduino.
...R
So you mean use a arduino mega with a ramps shield instead of a just a uno board?
Robin: I apologize, Your right. And thanks for pointing me to those drivers, I think that is what I'll use.
alltroid:
Using an Uno and trying to wire up everything yourself is definitely doing it the hard way. RAMPS with a Mega means you won't need a single breadboard or protoboard to get everything put together.
I agree that you won't need to use the full current/torque. You can buy a Mega clone and RAMPS board with A4988 driver boards at a very good price on eBay or DX.com.
Alright so here is what found
I have two alternatives with a $3.00 difference,
http://cart.payments.ebay.com/sc/view
but my question is, which would be the better route. I was reading a review on dx.com of someone who got a partly un assembled ramps. But on the other hand, can I trust getting parts all the way from hong kong on eBay?
Have you had good luck with dx.com?
Seems to be an awesome sight by the way. For the prices.
I've made around 6 orders with DX.com and never had any problem. Any orders I've made from Chinese eBay sellers have never had a problem either. DX has a pretty good reputation and Chinese eBay sellers tend to be pretty serious about their reputations (their feedback is right there for you to see, y'know). You'll find that these overseas shipments usually come with a generous wrapping of individual parts with bubble wrap and tucked into a small box that's well-sealed with tape. Quite arguably better packing than what you'll see from companies like Amazon that all tend to use those air bag things nowadays.
Biggest pain is the wait; to the US it's typically about 3 weeks.
On dx.com it says It "ships" within 7-10 days, does that mean it gets here by then or is that just the time it takes to process it. Forgive me if that is a dumb question :slight_smile:
I'm thinking of going with dx.com because eBay is 20 days out
Do I need two drivers for the 2 z axis motors? Or can i run them both from one drive, since they run in conjunction?
alltroid:
Every motor needs its own driver - otherwise the driver could not regulate the current. You could probably control the two drivers from the same Arduino step and direction pins.
...R
alltroid:
7-10 days + three weeks from China.
Okay so eBay is looking like the better option then for time.
I found a good deal on five motors. Is 50oz to under strength? they are six wires. Is there any way to run them with four wires/bipolar?
alltroid (and any one else) - please note that in the future, when you post an ebay link, most of the time you only need to post the part of the link prior to the "?" symbol; so - rather than:
...you can instead post the link as:
And it will work just fine (and look better).
50oz/in sounds typical. And again, if the stepper motors actually are too "weak" it just means your machine will need to run a little more slowly; torque decreases with RPM.
4-wire motors are bipolar only
5-wire motors are unipolar only
6 and 8-wire motors can be used in unipolar or bipolar mode
Looks like I forgot to include a link to stepper motor basics in my earlier replies.
...R
