3D printer filament runout issue
Hi, guys! I am new in this forum. In recent days, I am playing around with 3D printer (ramps 1.4+mega 2560). Until now, functions like print, auto-home, etc. have realized. But when there`s no filament, the printer still works until all the codes are finished. Yes, it is the Filament Runout issue.
For solving it, I changed some codes.
Configuration.h //========================= Filament Runout Sensor ========================== //===========================================================================
define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament
// In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made. // It is assumed that when logic high = filament available // when logic low = filament ran out
if ENABLED(FILAMENT_RUNOUT_SENSOR)
const bool FIL_RUNOUT_INVERTING = true; // Should be uncommented and true or false should assigned
define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
define FILAMENT_RUNOUT_SCRIPT "M600"
endif
Configuration_adv.h Line 445
ifdef ULTIPANEL
define FILAMENTCHANGEENABLE
ifdef FILAMENTCHANGEENABLE
define FILAMENTCHANGE_XPOS 0 // Tries to move to this position - Sometimes it will be at a different position to clear print position.
define FILAMENTCHANGE_YPOS 0 // Tries to move to this position - Sometimes it will be at a different position to clear print position.
define FILAMENTCHANGE_ZADD 10 // Increases distance between printhead and Z print platform by this amount
define FILAMENTCHANGE_FIRSTRETRACT -4.5
//#define FILAMENTCHANGE_FINALRETRACT -100
endif
endif
Marlin_main.cpp void manage_inactivity(bool ignore_stepper_queue/=false/) function.
if HAS_FILRUNOUT
if (!(READ(FILRUNOUT_PIN) ^ FIL_RUNOUT_INVERTING)) filrunout();
endif
Is there anyone faced this problem before? Welcom any kind of suggestion. Thank you!
I don't know if you are presenting a solution (if so, thank you) or asking for help. If you are asking for help what exactly is the problem.
In either case this is probably a subject that would be more at home on the RepRap Forum. Marlin is a very complex program and you need to find someone that understands it, or someone who needs your solution.
...R
