Hello,
I recently took the plunge and picked up a cheap 3D printer. One of the concerns with these printers is they have a tendency to catch fire under certain circumstances. Obviously, I don't want that to happen, so as one of my safety checks, I would like to do the following and would like to hear feedback on feasibility.
I want to use an Arduino + relay shield + smoke detector sensor as a safety shutoff switch. When smoke detector sensor reads above a certain input, shut the relay to stop more power from contributing to the problem. My question is this: I will also have a RPi running separately from the Arduino to perform a different task, therefore I would like to avoid having 3 power cords. To this end, I am wondering if it is possible to run the Arduino, whose relay is between the wall outlet and the printer PS, to run off the 12V output from the Printer PS. To do this I believe I would have to have a "Normally closed" relay so that the circuit is only open when a fault occurs. Question being is it possible to control the power with an Arduino that relies on that power to operate?
