Hi
I am building a 3D zoetrope. The following code is for the the power control circuit, and basically consists of a few pin outs and some timers. (There is another circuit for the strobe) I have wired up the circuit with simple LED’s standing in for the real components, and can’t achieve the behavior that the code describes.
At rest, PIN 5 is high
When PIN 3 is pulled low, PIN 5 goes low, PIN 4 goes high.
After 15 seconds (WAIT_TIME) it returns to its resting state.
In other words, timer2 does not seem to be working, and / or the behavior of the circuit is not that which the code describes.
Please take a look at the code and let me know if you see anything I am missing.
Thank you,
R
/* tiny trinket latching power circuit
* when button is pressed, turn motor on and send sig to leds-controller
* and turn off system in 90 seconds + the amount of time we need to wait for motor spin-up
* for subsequent button-presses while already running, restart the 90-second timer
* *This firmware works ONLY in conjunction with "LEDboard-proTrinket5vUSB" firmware
* modified feb 2016 to use 3v 8mhz 328p Arduino Pro Mini
#include <Bounce2.h>
#include "Timer.h"
#define ZOE_PIN 5 // this goes to the zoetrope circuit
#define MOT_PIN 4 // this goes to the powerswitch tail
#define BUTTON_PIN 3 //
// note as of feb 2016 the Pro Mini has one extra/unused connection to the
// power-button assembly; it's pro trinket pin 10 connected to Pro Mini pin 6
// 4/17/2016 adding pin 6 as always-on LED signal for the arcade button
#define BUTTON_LED 6
//note 4/17/2016 altering WAIT_TIME TIME from 40000 to 15000 in anticipation of better motor controller performance
#define WAIT_TIME 15000 // in ms, time to wait before all off and back to standby
unsigned long int DURATION = 180000; // 120 secs (clock speed is 8MHz not 16MHz)
unsigned long int TESTD = 1000 * 5; // 5 sec
int ledState = LOW;
int motorState = LOW;
Bounce debouncer = Bounce();
Timer *timer1 = new Timer(DURATION + WAIT_TIME);
Timer *timer2 = new Timer(WAIT_TIME);
pinMode(BUTTON_LED, OUTPUT);
digitalWrite(BUTTON_LED,HIGH);
// Setup the button with an internal pull-up :
pinMode(BUTTON_PIN, INPUT_PULLUP);
// After setting up the button, setup the Bounce instance :
debouncer.attach(BUTTON_PIN);
debouncer.interval(50);
// Setup the LED
pinMode(ZOE_PIN, OUTPUT);
pinMode(MOT_PIN, OUTPUT);
digitalWrite(ZOE_PIN, !ledState);
digitalWrite(MOT_PIN, motorState);
timer1->setOnTimer(&turnMotorAndLEDsOff);
// timer2->setOnTimer(&turnStrobeOn);
// Update the Bounce instance :
debouncer.update();
timer1->Update();
timer2->Update();
// Call this if Bounce fell (transition from HIGH to LOW) :
if ( debouncer.fell()) { // if button was pressed
if (motorState == LOW) { //if motor not running, turn it on and start led timer
motorState = HIGH;
ledState = HIGH;
timer1->Start();
timer2->Start(); // starts countdown till LEDs go HIGH also
} else { // if already running, prolong time till both are turned off
timer1->Stop();
timer1->Start();
// update all pins
digitalWrite(MOT_PIN, ledState);
void turnMotorAndLEDsOff() {
ledState = LOW;
motorState = LOW;
