3G-GSM HTTP Request Error
I'm at a loss and needing a helping hand here. I have purchased the 3G-GPS shield (http://www.cooking-hacks.com/index.php/documentation/tutorials/arduino-3g-gprs-gsm-gps#index) for Arduino and attempting to make an HTTP request with it. I've confirmed (by both sending raw AT commands via terminal and Arduino code) that I can both SMS and send email through the Arduino+3G Shield, however any HTTP request I try to do ends up with a vague "Network Error" (ID: 227) via terminal or "Error getting the URL" via the Arduino code below.
I'm attempting to just load http://bus3.sators.com/send-delete.php which loads fine via straight telnet using the same request headers below. Any thoughts?
I'm using AT&T - here's my code - thanks in advance!
 *  Description: This example shows how to do a GET method. So the buffer of
 *  is limited, we recommend to use the GET method with short answer for the
 *  requested webs.
 *  This example shows the AT commands (and the answers of the module) used
 *  to work with HTTP. For more information about the AT commands,
 *  refer to the AT command manual.
 *  Copyright (C) 2013 Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version 0.2
 *  Author: Alejandro Gallego
int8_t answer;
int onModulePin = 2, aux;
int data_size = 0;
int end_file = 0;
char aux_str[100];
char data[250];
int x = 0;
long previous;
char url[ ]="bus3.sators.com";
int port= 80;
char request[ ]="GET http://bus3.sators.com/send-delete.php HTTP/1.0";
char request2[ ]="Host: bus3.sators.com";
char request3[ ]="Content-Length: 0";
void setup(){
    pinMode(onModulePin, OUTPUT);
    Serial.println("Starting...");
    power_on();
    delay(3000);
    delay(3000);
    while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500) ||
        sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );
    // sets APN, user name and password
    sendATcommand("AT+CGSOCKCONT=1,\"IP\",\"broadband\"", "OK", 2000);
void loop(){
    // request the url
    sprintf(aux_str, "AT+CHTTPACT=\"%s\",%d", url, port);
    answer = sendATcommand(aux_str, "+CHTTPACT: REQUEST", 60000);
    if (answer == 1)
        Serial.println(request);
        Serial.println(request2);
        Serial.println(request3);
        // Sends
        aux_str[0] = 0x1A;
        aux_str[1] = 0x00;
        answer = sendATcommand(aux_str, "+CHTTPACT: DATA,", 30000);
        x=0;
        do{
            if (answer == 1)
                data_size = 0;
                while(Serial.available()==0);
                aux = Serial.read();
                do{
                    data_size *= 10;
                    data_size += (aux-0x30);
                while(aux != 0x0D);
                Serial.print("Data received: ");
                Serial.println(data_size);
                if (data_size > 0)
                    while(Serial.available() < data_size);
                    Serial.read();
                    for (int y = 0; y < data_size; y++)
                        data[x] = Serial.read();
                        x++;
                    data[x] = '\0';
                    Serial.println("Download finished");
                Serial.println("Error getting the url");
                data_size = 0;
            answer = sendATcommand2("", "+CHTTPACT: DATA,", "+CHTTPACT:0", 20000);
        }while (answer != 1);
        if (answer == 2)
            Serial.print("Data received:");
            Serial.println(data);
            Serial.println("Error getting data");
        Serial.println("Error waiting the request");
    delay(10000);
void power_on(){
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // waits for an answer from the module
        while(answer == 0){
            // Send AT every two seconds and wait for the answer
int8_t sendATcommand(char* ATcommand, char* expected_answer1,
            unsigned int timeout)
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial.available() != 0){
            response[x] = Serial.read();
            x++;
            // check if the desired answer is in the response of the module
            if (strstr(response, expected_answer1) != NULL)
                answer = 1;
        // Waits for the asnwer with time out
    while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
         char* expected_answer2, unsigned int timeout)
    char response[100];
    delay(100);
    x = 0;
    do{
            x++;
                answer = 1;
            if (strstr(response, expected_answer2) != NULL)
                answer = 2;
    return answer;
Normally the url is not included in the GET, just the document.
// change this
// to this
char request[ ]="GET /send-delete.php HTTP/1.0";
Thanks SurferTim, tried that - no change...
Hey I am getting same error.Did You get the solution?
If yes please post it!
