3g module
Hello,
I’m working in a project where I have to transmit data from arduino to a local server, I am using 3G/GPRS shield over Arduino from cooking hacks ( https://www.cooking-hacks.com/index.php/documentation/tutorials/3g-gps-shield-arduino-raspberry-pi-tutorial/)
I tried this tutorial: https://www.cooking-hacks.com/documentation/tutorials/how-to-upload-data-to-a-personal-cloud-server-using-3g-gps/
but it didn’t work, although I created the channels as mentioned but I didn’t know what url to use instead of api.thingspeak.com, what url I have to use?
 *  3G + GPS shield
 *  Copyright (C) Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see http://www.gnu.org/licenses/.
 *  Version:           1.0
 *  Design:            David Gasc?n
 *  Implementation:    Alejandro Gallego & Victor Boria
//Write here you SIM data
const char pin_number[] = "0000";
const char apn[] = "zain";
const char user_name[] = "zain";
const char password[] = "zain";
//Write here you Thingspeak data
const char APIWriteKey[] = "1R9Y2YFDOHFK00GA";
char url[ ]= "api.thingspeak.com/update?OUR_KEY=&field1=DATA_1&field2=DATA_2";
int port= 80;
int light = 15;  // Stores the light level
float temperature = 10.0; // Stores the calculated temperature
int sample;              // Counts through ADC samples
float ten_samples = 0.0; // Stores sum of 10 samples
int8_t answer;
int onModulePin = 2, aux;
int data_size = 0;
int end_file = 0;
char aux_str[100];
char data[800];
int x = 0;
long previous;
void setup(){
  pinMode(onModulePin, OUTPUT);
  Serial.println("Starting...");
  power_on();
  delay(3000);
  //sets the PIN code
  sprintf(aux_str, "AT+CPIN=%s", pin_number);
  sendATcommand(aux_str, "OK", 2000);
  delay(3000);
  while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500) ||
    sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );
  while( (sendATcommand("AT+CGREG?", "+CGREG: 0,1", 500) ||
    sendATcommand("AT+CGREG?", "+CGREG: 0,5", 500)) == 0 );
  // sets APN, user name and password
  sprintf(aux_str, "AT+CGSOCKCONT=1,\"IP\",\"%s\"", apn);
  sprintf(aux_str, "AT+CSOCKAUTH=1,1,\"%s\",\"%s\"", user_name, password);
void loop(){
  //light = analogRead(A1);
  //measure_temperature();
  //Send data to Thingspeak via HTTP GET
  send_data(light, temperature);
  //Wait a minute
  delay(60000);
 ****               Definition of functions                          ****
/*void measure_temperature()
  // take 10 samples from the MCP9700
  for (sample = 0; sample < 10; sample++) {
    // convert A0 value to temperature
    temperature = ((float)analogRead(A0) * 5.0 / 1024.0) - 0.5;
    temperature = temperature / 0.01;
    temperature = temperature - 5.3;
    // sample every 0.1 seconds
    delay(100);
    // sum of all samples
    ten_samples = ten_samples + temperature;
  // get the average value of 10 temperatures
  temperature = ten_samples / 10.0;
  ten_samples = 0.0;
void send_data(int _light, float _temperature){
  // request the url
  sprintf(aux_str, "AT+CHTTPACT=\"%s\",%d", url, port);
  answer = sendATcommand(aux_str, "+CHTTPACT: REQUEST", 60000);
  if (answer == 1)
    dtostrf(_temperature,2,1,data);
    // set the request
     sprintf(aux_str, "GET /update?key=%s&field1=%d&field2=%s HTTP/1.1\r\nHost: api.thingspeak.com\r\nContent-Length: 0\r\n\r\n", APIWriteKey, _light, data)  ;
    Serial.println(aux_str);
    // Sends "Ctrl+Z"
    aux_str[0] = 0x1A;
    aux_str[1] = 0x00;
    answer = sendATcommand(aux_str, "+CHTTPACT: 0", 60000);
    x=0;
    if (answer == 1)
      Serial.println("OK");
      Serial.println("Error sending the request");
    Serial.println("Error waiting the request");
  delay(10000);
void power_on(){
  uint8_t answer=0;
  // checks if the module is started
  answer = sendATcommand("AT", "OK", 2000);
  if (answer == 0)
    // power on pulse
    digitalWrite(onModulePin,HIGH);
    delay(3000);
    digitalWrite(onModulePin,LOW);
    // waits for an answer from the module
    while(answer == 0){
      // Send AT every two seconds and wait for the answer
int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout)
  uint8_t x=0,  answer=0;
  char response[100];
  unsigned long previous;
  memset(response, '\0', 100);    // Initialize the string
  delay(100);
  while( Serial.available() > 0) Serial.read();    // Clean the input buffer
  Serial.println(ATcommand);    // Send the AT command
    x = 0;
  previous = millis();
  // this loop waits for the answer
  do{
    if(Serial.available() != 0){
      if (x == 100)
        strncpy(response, response +1, 99);
        response[99] = Serial.read();
        response[x] = Serial.read();
        x++;
      // check if the desired answer is in the response of the module
      if (strstr(response, expected_answer1) != NULL)
        answer = 1;
    // Waits for the asnwer with time out
  while((answer == 0) && ((millis() - previous) < timeout));
  return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1, char* expected_answer2, unsigned int timeout)
  char response[100];
  delay(100);
    x = 0;
  do{
      x++;
        answer = 1;
      if (strstr(response, expected_answer2) != NULL)
        answer = 2;
  return answer;
post the code that you tried here, using code tags,
Ok I posted it
