3PDT Switch Coded to act as Momentary Button?
Hi, I'm relatively new to Arduino and programming so apologies in advance.
What I essentially want to do is use a 3PDT switch to save a 'preset' in EEPROM. The main problem is that obviously 3PDT switches are either off or on and was wondering is there a way to code so it acts as a momentary push button? (Only looks and stores the fact that the switch is on once and then ignores after a certain time)
In other words every time the switch is pressed it saves a number once until its pressed again and overwrites the number.
The reason I'm using 3PDT switches is because they will be controlled with feet in a guitar pedal so can't be tiny little things!
It would be great if someone could point me in the right direction code-wise that would be great as I have limited knowledge and experience.
Thanks,
James
So, you want to do something when the switch BECOMES on, not IS on? Look at the state change detection example.
