3phase metering IC
Greetings!
I work in a sub station. We monitor and log hourly data like voltage, current, power manually. There are 4 132kV lines, and 2 transformers 132/33kV. I want to automate the process. I planed to use ade7758 ic for monitor and logging purpose. Along with arduino and a pc to log the data. I searched this ic in aliexpress but I'm so confused with drastically price variation. What are alternative ics out there and where could i find them for affordable price.
Just to know what the sensor is alike I looked up the datasheet.
With the high voltage and energy in mind, cost shouldn't be a key factor, right?
my impression is that the ade7758 is designed for monitoring energy systems voltage range 100 to 250 volts per phase
Is this question related to ?
My thoughts too.
Even if this was part of an engineering research project under the supervision of the company, I don't think this is the way to go.
I did similar things developing monitoring equipment, but for a large utility.
This gives you a lot of clout to approach manufacturers like Analog Devices directly, with access to technical experts.
Certainly, some things were back of the envelope jobs, but you could always call in support when needed.
I'm not going to direct measure at that level though, i'll use existing CT/PT. Measured power will be multiplied by CT/PT ratio to get the actual reading.
No, the post you've mentioned is getting the chip working. I don't have the chip and I'm confused to order it from aliexpress. But I'm also want to do similar thing.
As a former industrial electrician (the guy using your project) who is working with the country specific electrical safety authority?
Before I would comment, I want to know your credentials and see a contract between you and your employer. If you are doing this on the side, hoping to impress your boss, I cannot legally assist.
I see them on Mouser for about $USD20 each. Seems reasonable to me. If you are super budget limited I would just buy a handful of the $1 versions from AliExpress along with SOIC to DIP adaptors. That way there’s a good chance at least one will work and you will easily be able to swap out a faulty one from your test rig.
The chip doesn’t know or care about the voltage that it’s measuring. It’s up to the end user to select suitable CT’s and burden resistors so that the analog input voltages fed to the chip don’t exceed 5V. The internal calcs are done as % of full scale, and they are then scaled to output real world values using constants Vfullscale and Ifullscale that the user has to enter.
Hi, @ras93
Welcome to the forum.
I assume you mean;
CT Current Transformer
PT Potential Transformer.
What voltage levels are on the output of these devices?
Tom.... :smiley: :+1: :coffee: :australia:
I agree that the IC is highly complicated and the price is fairly justified. I would buy it at this price if the project I'm intended would require high degree of accuracy and advanced feature. I saw $10 on analog device website though.
Thanks for your suggestion. I didn’t know tha soic to dip adaptor are available on market. Thanks again for the info very much.
Hi @TomGeorge
Thank you
CT ratio: 1600:5 (line CT), 300:5(Trafo. primary), 2400:5 (Tranfo. sec.)
PT ratio: 132/√3 kV : 110/√3 V
With such a system I would buy a commercial metering system - you have the issues of development , packaging, safety , documentation and so on . Who is going to install it , how will it be maintained ?
An IC is a long way from a monitoring system .
If I was your employer I would not allow hobby gear around such as system !
You can buy a 3 phase meter from a reputable supplier for around $1000.
May be I shouldn’t install a hobby solution in such a case. I agree with you. Still I want to give it a try.
And I Won't install it without necessary permission, and probably I Won't be given permission for it. Which employer would allow a nasty thing inside well dressed panel? I understand your point. If I am to going to do this type of project, I should go with some reliable commercial solution.
Thanks for eye opening advice. I should reconsider my thinking.
What I basically wanted was making a multifunctional meter (mfm) with communication port to fetch the data and view/log it on pc. I saw and inspired from subdivisional engineer from other substation who showed us such a project with existing mfm. But we Don't have any mfm installed in our panels with rs458 communication port.
