robvoi:
That's why I was hoping that there is something like a multi cell lipo shield. So a balancing charger I just need to supply with two contacts.
You want a LiPo battery management system on the battery, one that takes a simple 2 wire power source
as input and that can stay connected during discharge - normally this would be called a BMS.
An imbalance between cells can only be corrected if ALL cells are connected.
That is the main charging current. The balancing currents travel thru smaller gauge wires.
See attached image of a 3-cell LiPo under recharge on a Turnigy charger.
Charging at 2 points only cannot work because the cells cannot have exactly the same capacity. Inevitable one cell will overcharge. Overcharging not a good idea on LiPo cells. They contain finely divided Lithium metal and can burn vigourously when unhappy.
Trust me, I worked as a chemist with Lithium. You not want to see it catch fire.
Thanks for all the replies. What I then realy need is a complete Balancer and BPS - portable.
I think in this case it will be easier to build a solid five point connection for the robot and use my standard LIPO charger.
