3V EL inverter - how to control directly from Arduino
I got a 3V EL interver and 3m of blue EL wire. I found out the 3V output of the Arduino board is sufficient for it to light up.
It it possible (and a good idea) to control the EL inverter to the arduino power supply and control it with a digital pin? Or, could it even be powered by the signal of a digital pin?
(Yes I am quite noobish with electronics, please type your answer loud and slowly... ;))
How's this:
poooooooosssst aaaa liiiiinnnnkkkkk tooooooo theeeeeee paaaaarrrrrttttssssss.....
CrossRoa, I can read you loud and clear!
It is this 3V EL inverter: http://www.sparkfun.com/products/10201 Datasheet: http://www.sparkfun.com/datasheets/Components/LED/SPECIFICATION%20of%203V3M%20-%20%E5%89%AF%E6%9C%AC.pdf And this 3m length EL wire: http://www.sparkfun.com/products/10195 Datasheet: http://www.sparkfun.com/datasheets/Components/LED/Technical%20Information%20of%20Flexible%20Neon%20wire.pdf and an Arduino UNO
KE7GKP, the board is neither sweating nor smoking, and still alive. I have seen the EL Escudo and other EL shields but am wondering whether I can spare the expenses.
KE7GKP, thanks a lot for your advice and explanation of the UNO board! This pretty much means I should have used relays/optoelectric couplers many times before :roll_eyes:
I'll have close look at the UNO datasheet and get an ampmeter right away...
