Hello,
I have a 3V motor, it is my first time using this motor
and i don't know how to connect this motor to the Arduino.
can anyone help me to sort the pinout of the motor.
thanks in advance
Hello,
thanks in advance
In principle, like this, although various different transistors will do the trick.
If you want the motor to rotate in both directions, you will need a low voltage brushed D.C. motor driver. This one is a good choice.
Always use a separate power supply for the motor (with the grounds connected together), or you will have problems with the Arduino.
m3o0od:
Actually it's an assumption on my part that this is a simple 2-wire dc motor, but with you asking for help on the motor's pinout, I'm wondering if that's not correct.
If it's not a simple 2-wire dc motor, best post details and a pic for better advice.
