Hello Everyone, I have 2 Questions but they are pretty similar so I guessed putting them in one topic is OK. Anyway, I have A 3W High power LED (Shown in picture below): and I want to use it as a bicycle headlight.The question is that is the onboard heatsink good enough for a max of like 2 hours of use per day. if not I want the most compact solution maybe a raspi fan or small raspi hesatsink would do?
2nd question, I have 2 16 led neopixel rings one for front turn signals and one for rear brakes or turn signals. Is its onboard mounting thing good as a heatsink for it or not?
The star base will overheat fast if not mounted on a heatsink (with thermal glue). How fast depends on how much current you drive the LED with. Those LEDs are usually driven with 660mA, which is about 2watt. 3watt would require a stable 1Amp from a constant current driver, and a heatsink the size you see on an LM298 motor driver module.
A bike light also needs a reflector, because you want a narrow beam (not the 120 degrees from that LED) that doesn't blind oncoming trafic. Maybe it's better to buy a factory-made LED bikelight
Leo..
I have but I want a smaller solution so i thought a fan would make me be able to compromise on the heatsink surface area (also if with a fan it would be sufficient which direction should it blow with the incoming wind or opposite
