I've been working on a 3x3 led matrix that displays a random digit 1-6 at the push of a button. The purpose is to mimic a dice. While individualy addressing the LEDs would be easier, I wanted to make them into a 3x3 LED matrix instead. While my code looks as though it should work, I am too inexperienced to find out why it is not. I have determined that my wiring and components are good.
My code is as follows:
const int r1 = 2; //Rows 1-3
const int r2 = 3;
const int r3 = 4;
const int c1 = 5; //Colloms 1-3
const int c2 = 6;
const int c3 = 7;
const int b1 = 8; //The Button
int b1State = 0; //The Button's State, not a constant (const) intiger (int) because it changes
int rNumber = 2; //Holds the value of a randomly generated number;
int dValue = 0; //Holds the value
int wait = 5;
void setup() { //Required, only runs once in an Arduino during startup
pinMode(r1, OUTPUT); //Sets the pins as outputs
pinMode(r2, OUTPUT);
pinMode(r3, OUTPUT);
pinMode(c1, OUTPUT);
pinMode(c2, OUTPUT);
pinMode(c3, OUTPUT);
pinMode(b1, INPUT); //Sets the button pin to input
randomSeed(analogRead(0)); //Begins the generation of random numbers
} //Closes off void setup()
void loop() { //As its name implies, this section loops forever
//Ties the physical button pin to the intiger value, changing it when the button is pressed
b1State = digitalRead(b1);
if (b1State == HIGH) { //Checks if the button is pressed, then does something
rNumber = random(0, 5); //Generates a random number 0 - 5 and sets rNumber to that number
delay(1000); //Stops the program for 1000 milliSeconds, or 1 Second
//Displays number 1
while (rNumber == 0) { //During the time that rNumber is exactly equal to 0, the display will continue to loop these commands
digitalWrite(r1, LOW); //Sets the row to low shutting voltage off
digitalWrite(r2, HIGH); //Sets row 2 to high applying voltage to the led
digitalWrite(r3, LOW);
digitalWrite(c1, HIGH);
digitalWrite(c2, LOW); //Sets the collumb to low, allowing voltage to travel though it
digitalWrite(c3, HIGH);
//Displays number 2
while (rNumber == 1) {
if (dValue == 0) { //Because 2 LEDs must be lit, each must be individualy addressed
digitalWrite(r1, HIGH); //An if statement inside a while statement does nicely
digitalWrite(r2, LOW); //Using the principle of Persistance of Vision (POV)
digitalWrite(r3, LOW); //The LEDs appear to be lit even when they are not because
digitalWrite(c1, HIGH); //They are being switched on and off too quickly to be seen
digitalWrite(c2, HIGH);
digitalWrite(c3, LOW);
delay(wait);
dValue++; //Increses dValue by one, making the previous statement false in the next loop
else {
digitalWrite(r3, HIGH); //Sets the row to high, applying voltage to it
digitalWrite(c1, HIGH); //Sets the collumb to high, stopping the flow of electricity by
digitalWrite(c2, HIGH); //Applying the same ammount of voltage on either side of the LED
digitalWrite(c3, LOW); //And shutting the LED off
delay(wait);
dValue = 0; //Sets the dValue to 0 for the next loop
//Displays number 3
while (rNumber == 2) {
if (dValue == 0) {
digitalWrite(c1, LOW);
delay(wait);
dValue++;
if (dValue == 1)
{ //An addational if statement is needed to complete the liting of the third LED
delay(wait);
dValue++;
else {
delay(wait);
dValue = 0;
//Displays number 4
while (rNumber == 3) {
if (dValue == 0) {
delay(wait);
dValue++;
if (dValue == 1) {
delay(wait);
dValue++;
if (dValue == 2) {
delay(wait);
dValue++; //Another addational step is needed to display the fourth LED
else {
delay(wait);
dValue = 0;
//Displays number 5
while (rNumber == 4) {
if (dValue == 0) {
delay(wait);
dValue++;
if (dValue == 1) {
delay(wait);
dValue++;
if (dValue == 2) {
delay(wait);
dValue++;
if (dValue == 3) {
delay(wait);
dValue++;
else {
delay(wait);
dValue = 0;
//Displays number 6
while(rNumber == 5) {
if (dValue == 0) {
delay(wait);
dValue++;
if (dValue == 1) {
delay(wait);
dValue++;
if (dValue == 2) {
delay(wait);
dValue++;
if (dValue == 3) {
delay(wait);
dValue++;
if (dValue == 4) {
delay(wait);
dValue++;
else {
delay(wait);
dValue = 0;
} //Ends void loop, and returns the program to its beginning
Any help is much appreciated. Cheers!
