3zone cymbal no sound
I tried to make a 3zone cymbal. I'm wiring as the RyoKosaka's schematic diagram , but no response. What is the problem?
byte RIDE[10] = {
    100, //sensitivity
    10,  //threshold
    10,  //scan time
    30,  //mask time
    4,   //edge threshold
    9,   //cup threshold
    1,   //curve type(0-4)
    60,  //note of bow
    62,  //note of edge
    61   //note of cup
#include <hellodrum.h>
//Using MIDI Library. If you want to use USB-MIDI, comment out the next two lines.
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
//Please name your cymbal.
//The cymbal named ride is connected to the A0 pin (piezo) and A1 pin (edge sensor).
HelloDrum ride(5, 6);
  MIDI.begin();
  Serial.begin(38400);
  //Set Curve Type
  ride.setCurve(RIDE[6]);
  //Piezo sensing is done in this line. And it is returned as a velocity of 127 stages.
  //For each pad, one line is required.
  //So, you need the same number of lines as the number of pads or controller.
  ride.cymbal3zone(RIDE[0], RIDE[1], RIDE[2], RIDE[3], RIDE[4], RIDE[5]); //cymbal3zone(byte sens, byte thre, byte scan, byte mask, byte edgeThre, byte cupThre);
  //MIDI signals are transmitted with this IF statement.
  //bow
  if (ride.hit == true)
    MIDI.sendNoteOn(RIDE[7], ride.velocity, 10); //(note, velocity, channel)
    MIDI.sendNoteOff(RIDE[7], 0, 10);
  //edge
  else if (ride.hitRim == true)
    MIDI.sendNoteOn(RIDE[8], ride.velocity, 10); //(note, velocity, channel)
    MIDI.sendNoteOff(RIDE[8], 0, 10);
  //cup
  else if (ride.hitCup == true)
    MIDI.sendNoteOn(RIDE[9], ride.velocity, 10); //(note, velocity, channel)
    MIDI.sendNoteOff(RIDE[9], 0, 10);
  //choke
  if (ride.choke == true)
    MIDI.sendPolyPressure(RIDE[7], 127, 10);
    MIDI.sendPolyPressure(RIDE[8], 127, 10);
    MIDI.sendPolyPressure(RIDE[9], 127, 10);
    MIDI.sendPolyPressure(RIDE[7], 0, 10);
    MIDI.sendPolyPressure(RIDE[8], 0, 10);
    MIDI.sendPolyPressure(RIDE[9], 0, 10);
Fritzing is a mess....redraw in conventional manner.(plus not fritzing)
Hello willtcs
You might use the search engine of the forum to get addtional ideas about cymbal and Arduino.
There is no power source connected....
which pin no power connected?
I searched there's no information about cymbal
more of question were issue by me
