AFAIK the sketch for different thermistor values is the same if the fixed resistor matches the thermistor value.
The ratio (output voltage on the tap) stays the same (if thermistor specs are the same).
The third sketch on this page has the option of entering a different value for VCC (it never is exactly 5.0volt).
And a value for the thermistor (thermr) , and pull up resistor (pad).
Thermistor circuits are far from accurate. They need calibration.
IMHO only good for crude thermostats.
There is an online calculator ([SRS Thermistor Calculator](http://"http://www.thinksrs.com/downloads/programs/Therm Calc/NTCCalibrator/NTCcalculator.htm")) for the Steinhart-Hart coefficients that describe the Temperature-Resistance curve. You need to measure the resistance at three known temperatures and enter those pairs into the online calculator. With the coefficients you can calculate the temperature for any resistance.
