I have a Parallax 360 high speed servo motor, and I am trying to power it using 4 AA batteries wired in parallel. The servo should be able to run on 6 volts (which is what my batteries provide if I am not mistaken). The control pin is in port 5 on my Arduino Uno and I have this code uploaded onto it:
#include<Servo.h>
Servo myServo1;
myServo1.attach(5);
myServo1.write(72);
It should be able to go right? or can I not power this servo with AA batteries
ForestSkis98:
#include<Servo.h>
Servo myServo1;
myServo1.attach(5);
myServo1.write(72);
you want to run them in series ( positive to negative positive to negative ect. ect.)
Perhaps I misspoke and it is in series, I'm pretty new to all this stuff. I am using this battery pack: Amazon.com. By my understanding, that should produce 6 volts, right?
Ah ok, I see what you mean now. I attached ground from arduino to ground on the servo, and ground from the servo to the black wire on my battery pack. That did it, thanks for the help!
ForestSkis98:
ForestSkis98:
They are not wired in parallel, they are wired in series in that battery holder.
Note these cheap plastic battery holders are not really designed for high current, being of simple riveted construction. I've had trouble with them developing significant resistance at the rivets.
High performance servos often require high peak currents, and often this isn't even documented, so you can't afford to skimp (many many postings here are due to people misjudging the current requirements of servos).
MarkT:
But whre would on find good quality battery holders? I have not looked much but the regular sources like Sparkfun & Adafruit sell what looks like things that I refer to as "competitive bid"
If you connect a 30 ohm /2@ resistor across your battery pack it should draw 6V/30= 0.2A.
If it does not ,there is something wrong with your batteries.
