4 button 8 number pin lock (editable pin)
Hi everyone,
I'd like you to help me.
I have four buttons and an 8 number pin and 3 output leds. If i press the buttons in the right way, the program grants the access. If i press them in wrong way, the access denied. This is okay. but i'd like to check the pressed buttons right after pressing, not after all the 8 numbers inputted.
I have another problem, i'd like to restart the button listening after 2 seconds without button press.
Here is the code:
const int greenled = 6;
const int redled = 7;
const int ackled = 11;
const int b1 = 9;
const int b2 = 2;
const int b3 = 3;
const int b4 = 4;
int timer_ackled = 400;
int pwcount;
byte combination[] = "12314241";
long userInput[9];
int buttonstate1 = 0;
int buttonstate2 = 0;
int buttonstate3 = 0;
int buttonstate4 = 0;
  pinMode(greenled, OUTPUT);
  pinMode(redled, OUTPUT);
  pinMode(b1, INPUT);
  pinMode(b2, INPUT);
  pinMode(b3, INPUT);
  pinMode(b4, INPUT);
void loop(){
  buttonstate1 = digitalRead(b1);
  buttonstate2 = digitalRead(b2);
  buttonstate3 = digitalRead(b3);
  buttonstate4 = digitalRead(b4);
  if (buttonstate1 == HIGH){
    userInput[pwcount] = '1';
    pwcount++;
    delay(300);
    Serial.print('1');
      digitalWrite(ackled, HIGH);
      delay(timer_ackled);
      digitalWrite(ackled, LOW);
  if (buttonstate2 == HIGH){
    userInput[pwcount] = '2';
    pwcount++;
    delay(300);
    Serial.print('2');
  if (buttonstate3 == HIGH){
    userInput[pwcount] = '3';
    pwcount++;
    delay(300);
    Serial.print('3');
    if (buttonstate4 == HIGH){
    userInput[pwcount] = '4';
    pwcount++;
    delay(300);
    Serial.print('4');
  for(long n = 0; n <=8; n++){
    if (userInput[pwcount] == combination[n] && pwcount >=8){
      Serial.println(" access granted");
      digitalWrite(redled, LOW);
      digitalWrite(greenled, HIGH);
      delay(10000);
      digitalWrite(greenled, LOW);
      pwcount = 0;
    else {
      if(userInput[n] != combination[n] && pwcount >=8){
        Serial.println(" access denied");
        digitalWrite(redled, HIGH);
        delay(3000);
        pwcount = 0;
        n = 0;
Thank you for helping me, good evening
layerke:
For this part, just store the current millis() when any button is pressed, then every time through the loop see if the difference between current millis() and lastButtonPressedMillis is > 2 seconds. If so, reset your state machine.
arduinodlb:
I never used this thing and don't know how to implement it or where.. Can you please explain the method to do this?
layerke:
A cleaner way is to check every button against the current index, instead of using a for loop.
But, this will do for a first pass for now, change your loop to something like (untested):
  byte valid = 1; // assume all is good. Then check the sequence
  for(byte n = 0; n < pwcount; n++){
    if (userInput[n] != combination[n]){
        valid = 0;
  if (valid == 1 && pwcount == 8)
      // do access granted
  else if (valid == 0)
      // bad code. Reset some stuff??
layerke:
http://lmgtfy.com/?q=arduino+millis
The for loop at the bottom of loop() does not make sense to me. I would do something like the following.
const int b1 = 9;
const int b2 = 2;
const int b3 = 3;
const int b4 = 4;
const int IDLE_TIMEOUT = 2000;  // reset if no buttons pressed
unsigned long timeOutStart;     // start of inactiviity
int pwcount=0;                 // index into arrays
long userInput[9];
  pinMode(b1, INPUT);
  pinMode(b2, INPUT);
  pinMode(b3, INPUT);
  pinMode(b4, INPUT);
  timeOutStart = millis();  // mark start of inactivity
void loop(){
  boolean buttonPressed = false; // true => button pressed
    buttonPressed = true;        // set flag
    Serial.print('1');
    Serial.print('2');
    Serial.print('3');
    Serial.print('4');
  // if a button was pressed
  if( buttonPressed )
    timeOutStart = millis(); // reset timeout
    // if not correct digit
    if( userInput[pwcount] != combination[pwcount] )
      delay(3000);
      pwcount = 0;
    else {
      // correct digit entered, got tull combo?
      if( pwcount == 7 )
        delay(10000);
        pwcount = 0;
      else {
        // no, increment index
        pwcount++;
      } // else
    } // else
  } // if
  else {
    // no button press, check for timeout
    if( (millis() - timeOutStart) >= IDLE_TIMEOUT )
      // start over
      Serial.println(" timeout!");
      delay(10000);
      pwcount = 0;
    } // if
  } // else
Thank you very much, this is the way i wanted this code. I tried to put in a counter, but if i pressed the first button it was okay, and the second button always gave me an access denied. This code is perfect, i made a little change in start over section, like this:
      // start over
      delay(3000);
      pwcount = 0;
    } // if
  } // else
Thank you again Sir, i highly appreciate your help
