4 Buttons 4 LEDs
I have a MIDIUSB sketch I am using with mini arcade buttons that have LEDs included in them.
I am looping through an array of the buttons and the LEDs but the LED just stays lit or does not light.
Button: Mini LED Arcade Button - 24mm Translucent Clear : ID 3429 : $2.50 : Adafruit Industries, Unique & fun DIY electronics and kits
[]-Ground |-5V
[]-Pin 2 |-Pin 6
My goal is if i press button 1 --> led 1 will remain lit until i press another button. I am using the same variable "i" to get the index of the array.
#include "MIDIUSB.h"
#include "PitchToNote.h"
#define NUM_BUTTONS  4
const uint16_t button1 = 2;
const uint16_t button2 = 3;
const uint16_t button3 = 4;
const uint16_t button4 = 5;
const uint16_t led1 = 6;
const uint16_t led2 = 7;
const uint16_t led3 = 8;
const uint16_t led4 = 9;
const uint16_t buttons[NUM_BUTTONS] = {button1, button2, button3, button4};
const uint16_t LEDS[NUM_BUTTONS] = {led1, led2, led3, led4};
const byte notePitches[NUM_BUTTONS] = {pitchC2, pitchD2b, pitchD2, pitchE2b};
uint16_t notesTime[NUM_BUTTONS];
uint16_t pressedButtons = 0x00;
uint16_t previousButtons = 0x00;
uint16_t pressedLEDS = LOW;
uint16_t previousLEDS = HIGH;
uint16_t intensity;
  for (int i = 0; i < NUM_BUTTONS; i++)
    pinMode(buttons[i], INPUT_PULLUP);
    pinMode(LEDS[i], OUTPUT);
  readButtons();
  readLEDS();
  playNotes();
  playLEDS();
void controlChange(byte channel, byte control, byte value) {
  midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
  MidiUSB.sendMIDI(event);
void readButtons()
    if (digitalRead(buttons[i]) == LOW)
      bitWrite(pressedButtons, i, 1);
      delay(2);
      bitWrite(pressedButtons, i, 0);
void playNotes()
    if (bitRead(pressedButtons, i) != bitRead(previousButtons, i))
      if (bitRead(pressedButtons, i))
        bitWrite(previousButtons, i , 1);
        noteOn(0, notePitches[i], 100);
        MidiUSB.flush();
        bitWrite(previousButtons, i , 0);
        noteOff(0, notePitches[i], 0);
        MidiUSB.flush();
void readLEDS()
      bitWrite(pressedLEDS, i, LOW);
      delay(2);
      bitWrite(pressedLEDS, i, HIGH);
void playLEDS()
      if (bitRead(pressedLEDS, i))
        bitWrite(previousLEDS, i, LOW);
        bitWrite(previousLEDS, i, HIGH);
void noteOn(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
  MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
  MidiUSB.sendMIDI(noteOff);
sketch_may07a.ino (2.68 KB)
Welcome to the Forum. Please read these two posts:
General Guidance and How to use the Forum
and
Read this before posting a programming question ...
You may also find useful information that would answer your question here:
Useful links - check here for reference posts / tutorials
It is important to provide as much of the information that is needed to solve your problem as you can, in your first posts. The forum link above has guidelines for posting in a standard way that makes it easiest for people to provide you with useful answers. Making an effort to do this will greatly increase the number and quality of helpful responses that you get.
You have added your sketch as an attachment. Unless the sketch is too large, it's better if you post your code (using code tags!), rather than attach it. When it's attached, we have to download it, create a folder then open your code in our IDE. And afterwards, the folder remains unless we navigate to the "Temp" folder and manually remove it. It's much easier to just view the code in your post.
Please edit your post and insert your code inside it, using code tags. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don't do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons. The "Code: [Select]" feature allows someone to select the entire sketch so it can be easily copied and pasted into the IDE for testing.
