4 cascaded MAX7219 modules, how can I program the text to start from the first
// Program to demonstrate the MD_Parola library
// Uses the Arduino Print Class extension with various output types
// MD_MAX72XX library can be found at GitHub - MajicDesigns/MD_MAX72XX: LED Matrix Library
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
const uint16_t WAIT_TIME = 1000;
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 11
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// Hardware SPI connection
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// Arbitrary output pins
// MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
char myString[] = " class "
" subject "
" time "
" prof ";
void setup(void)
P.begin();
void loop(void)
P.print(myString);
Well, for a start
needs to be 16, not 11.
Secondly, this
" subject "
" time "
" prof ";
defines one long string. Is that your intention? Or are you trying to define 4 different messages?
It is hard to read your mind, so you really need to explain what you are trying to do with this code.
If you use print you don't have any options for formatting. Read some of the other examples and the extensive documentation for the library to see if that gives you any ideas.
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Those modules with the right angle pin headers are a real pain. Almost impossible to work with if the displays are not socketed as you cannot un-solder the headers. Probably cut the header pins off at the right angle and solder them together, one to the next with little pieces of wire.
Or better, twist the right angle part ever so slightly so that when you put the adjacent boards together, they just slip together, cur the pins short so that there is about 4 mm overlap and just solder the overlapped pins together.
