Hy everybody,
I like to use the case instead a Loop (for/while etc.)
Case 1 should be started with an Switch (Main program)
Case 2 should be started with a photocell (error 1) and Interrupt case1 & default
Case 3 should be started with the second photocell (error 2) and Interrupt case 1 & default
Case 4 / default should be the Standby program (green LED on High until an other Case is running)
So I just need help to do that without an PC so that I could use a button/Switch.
I can't find any code/Sketch which could do this, so I would be happy If anyone could help me.
Kindly regards
Dennis
You have already made a start by defining the cases, which is good.
Some pseudo code to give you some ideas
case = 4
start of loop()
switch (case)
case 1
run main program
case 2
run code for case 2
case 3
run case for case 3
case 4
turn on green LED
end of switch
if switch is turned on
case = 1
end if
if photocell 1 turned on
case = 2
end if
if photocell 2 turned on
case = 3
end if
end of loop()
Yes, it's exactly what I need.
THX for your time.
But now I don't know how I could integrate my switch into the case code. Yesterday I've tried the 4 case code with some LED's to test it, but i must engerfir case 1 a "1" into the Arduino program, i don't know how i could use a switch instead my PC running the Arduino Software.
Sry for my Bad english.
Kindly regards
Dennis
When you say switch do you mean a physical switch or a software switch/case ?
If the former do you know how to read the state of a switch connected to a pin ?
Hello,
yes i know
I could usw them
int inPin = 2; // the number of the input pin
int outPin = 13; // the number of the output pin
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
pinMode(inPin, INPUT);
pinMode(outPin, OUTPUT);
But how could i integrat a physical switch into the case code /sketch?
Look at my pseudo code in post #1. The suggestion is to read the state of the physical switch after the switch/case so that it is read on every pass through loop()
thx, but I don't get it
i've tried it, but I Don't know where to write the my contions in the cases,
so I need a compare between 2 photoresistor analog signal and between a digital button
both photoresistors Don't get light, button ON> Program should start
one photoresistors Don't get light, button ON> Program shouldn't start
both photoresistors get light, button ON> Program shouldn't start
i like to write this in a if/else or in a 4 case switch statement,
int sensorPin = A0; //photoresistor1
int sensorPin1 = A1; //photoresistor2
int sensorValue1 = 0;
int sensorValue2 = 1;
int ledPin = 13;//green
int ledPin1 = 4;//blue
int ledPin2 = 2;//red
int tasterPin = 5; //physical button (START,Normaly Open)
pinMode(ledPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
sensorValue2 = analogRead(sensorPin1)/4;//0-1023 zu 0-255
Serial.println(sensorValue2);
sensorValue1 = analogRead(sensorPin)/4;
if (sensorValue1 < 100) {
digitalWrite(ledPin, HIGH);
delay(100);
else if (sensorValue1 > 100){
digitalWrite(ledPin1, HIGH);
delay(100);
if (sensorValue2 > 100){
digitalWrite(ledPin2, HIGH);
delay(100);
button code
int ledPin = 13;
int tasterPin = 5;
void setup(){
pinMode(ledPin,OUTPUT);
pinMode(tasterPin,INPUT);
void loop(){
if (digitalRead(tasterPin)==HIGH){
digitalWrite(ledPin, LOW);
photoresistior code
int sensorPin = A0;
int ledPin = 13;
sensorValue1 = analogRead(sensorPin)/4;//0-1023 zu 0-255
Serial.println(sensorValue1);
delay(100);
many thanks,
now I have a good base for case statements, until now i just used the if/else
// 2xPhotocell Interrupted
// + Pressing Button Starts the program
// Program does not start
// Nearby a light barrier ( empty container)
// Or no pressing of the switch ( contact)
int sensorPin = A0; //Photocell 1
int sensorPin2 = A1; //Photocell 2
int sensorValue2 = 1; //Photocell 1 Value
int sensorValue1 = 0; //Photocell 2 Value
int ledPin = 13; //Green LED
int ledPin2 = 2; //Red LED
int ledPin3 = 3; //Yellow LED
int ledPin4 = 4; //Blue LED
int tasterPin = 5; //Button (Normaly Open)
//colorful LED's just for demonstration
sensorValue1 = analogRead(sensorPin)/256;//0-1023 zu 0-255
sensorValue2 = analogRead(sensorPin2)/256;
if (sensorValue1 >2&&sensorValue2 >2&&digitalRead(tasterPin)==HIGH ) {
digitalWrite(ledPin2, LOW);
delay(250);
delay(250);
digitalWrite(ledPin3, HIGH);
delay(250);
digitalWrite(ledPin4, HIGH);
delay(250);
delay(250);
digitalWrite(ledPin3, LOW);
delay(250);
digitalWrite(ledPin4, LOW);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
digitalWrite(ledPin2, HIGH);//Standby/Error
but now I use 2 more functions, because i like to have
-standby program
-Main Program
-Error1 Program
-Error2 Program
so that I could see on LED'S which of this program runs
