4 CHANNEL (LM35 PWM) FAN CONTROLLER QUESTION
Hello friends,
Hello friends, I’m having this big problem in programming, where I noticed a big GAP in the reaction of the last 3 engines. I’m new to C ++ programming and I find it very hard to syntax and file structure, so if anyone can help me I’ll happily spend the entire Proteus project! (attached yet !)
Is there any way to define variables that make the program clean ?
Thank you !
// BLOCO DE PINOS DOS SENSORES
float temp;
float temp2;
float temp3;
float temp4;
int tempPin = A3; // PINO ANALOGICO (CPU) PRA USAR O LM35
int tempPin2 = A2; // PINO ANALOGICO (CASETOP) PRA USAR O LM35
int tempPin3 = A1; // PINO ANALOGICO (HD) PRA USAR O LM35
int tempPin4 = A0; // PINO ANALOGICO (RESERVADO) PRA USAR O LM35
// BLOCO DE TEMPERATURA MINIMA
int tempMin = 20; // TEMPERATURA MINIMA PRA RODAR O FAN (CPU)
int tempMin2 = 25; // TEMPERATURA MINIMA PRA RODAR O FAN (CASETOP)
int tempMin3 = 25; // TEMPERATURA MINIMA PRA RODAR O FAN (HD)
int tempMin4 = 25; // TEMPERATURA MINIMA PRA RODAR O FAN (RESERVADO)
// BLOCO DE TEMPERATURA MAXIMA
int tempMax = 45; // TEMPERATURA MAXIMA (CPU)
int tempMax2 = 38; // TEMPERATURA MAXIMA (CASETOP)
int tempMax3 = 40; // TEMPERATURA MAXIMA (HD)
int tempMax4 = 40; // TEMPERATURA MAXIMA (RESERVADO)
// BLOCO DE PINOS DOS FANS
int fan = 11; // PINO PWM ONDE O FAN (CPU) SERA CONECTADO
int fan2 = 10; // PINO PWM ONDE O FAN (CASETOP) SERA CONECTADO
int fan3 = 9; // PINO PWM ONDE O FAN (HD) SERA CONECTADO
int fan4 = 6; // PINO PWM ONDE O FAN (RESERVADO) SERA CONECTADO
// ZERA VARIAVEIS DE TODOS OS FANS
int fanSpeed = 0; // (CPU)
int fanSpeed2 = 0; // (CASETOP)
int fanSpeed3 = 0; // (HD)
int fanSpeed4 = 0; // (RESERVADO)
pinMode(fan, OUTPUT); // (CPU)
pinMode(fan2, OUTPUT); // (CASETOP)
pinMode(fan3, OUTPUT); // (HD)
pinMode(fan4, OUTPUT); // (RESERVADO)
pinMode(tempPin, INPUT); // (CPU)
pinMode(tempPin2, INPUT); // (CASETOP
pinMode(tempPin3, INPUT); // (HD)
pinMode(tempPin4, INPUT); // (RESERVADO)
//BLOCO DE TESTE DAS PORTAS (TRANSISTORES DE SAIDA) POR 2 SEGUNDOS DEPOIS DE ALIMENTADO
digitalWrite(fan, HIGH);
delay(2000);
digitalWrite(fan, LOW);
digitalWrite(fan2, HIGH);
delay(2000);
digitalWrite(fan2, LOW);
digitalWrite(fan3, HIGH);
delay(2000);
digitalWrite(fan3, LOW);
digitalWrite(fan4, HIGH);
delay(2000);
digitalWrite(fan4, LOW);
temp = analogRead(tempPin);
temp2 = analogRead(tempPin2);
temp3 = analogRead(tempPin3);
temp4 = analogRead(tempPin4);
temp = (temp *5.0*100.0)/1024.0; // CALCULA TEMPERATURA EM GRAUS CELCIUS
temp2 = (temp2 *5.0*100.0)/1024.0; // CALCULA TEMPERATURA EM GRAUS CELCIUS
temp3 = (temp3 *5.0*100.0)/1024.0; // CALCULA TEMPERATURA EM GRAUS CELCIUS
temp4 = (temp4 *5.0*100.0)/1024.0; // CALCULA TEMPERATURA EM GRAUS CELCIUS
Serial.print("CPU ----------------- ");
Serial.println (temp);
Serial.print("");
Serial.print("CASETOP ------------- ");
Serial.println(temp2);
Serial.print("");
Serial.print("HD ------------------ ");
Serial.println(temp3);
Serial.print("");
Serial.print("RESERVADO ----------- ");
Serial.println(temp4);
Serial.print("");
delay(1000); // ATRASO EM MILI SEGUNDOS PRA ESTABILIDADE
if(temp < tempMin) { // SE TEMPERATURA MAIS BAIXA QUE tempMin
fanSpeed = 0; // FAN NAO RODA
if(temp2 < tempMin2) { // SE TEMPERATURA MAIS BAIXA QUE tempMin2
fanSpeed2 = 0; // FAN2 NAO RODA
if(temp3 < tempMin3) { // SE TEMPERATURA MAIS BAIXA QUE tempMin3
fanSpeed3 = 0; // FAN3 NAO RODA
if(temp4 < tempMin4) { // SE TEMPERATURA MAIS BAIXA QUE tempMin4
fanSpeed4 = 0; // FAN4 NAO RODA
if((temp >= tempMin) && (temp <= tempMax)) // SE A TEMPERATURA É MAIOR QUE A FAIXA
fanSpeed = map(temp, tempMin, tempMax, 32, 255); // VELOCIDADE ATUAL DO FAN
analogWrite(fan, fanSpeed); // spin the fan at the fanSpeed speed
if((temp2 >= tempMin2) && (temp2 <= tempMax2)) // SE A TEMPERATURA É MAIOR QUE A FAIXA
fanSpeed2 = map(temp2, tempMin2, tempMax2, 32, 255); // VELOCIDADE ATUAL DO FAN
analogWrite(fan2, fanSpeed2); // spin the fan at the fanSpeed speed
if((temp3 >= tempMin3) && (temp3 <= tempMax3)) // SE A TEMPERATURA É MAIOR QUE A FAIXA
fanSpeed3 = map(temp3, tempMin3, tempMax3, 32, 255); // VELOCIDADE ATUAL DO FAN
analogWrite(fan3, fanSpeed3); // spin the fan at the fanSpeed speed
if((temp4 >= tempMin4) && (temp4 <= tempMax4)) // SE A TEMPERATURA É MAIOR QUE A FAIXA
fanSpeed4 = map(temp4, tempMin4, tempMax4, 32, 255); // VELOCIDADE ATUAL DO FAN
analogWrite(fan4, fanSpeed4); // spin the fan at the fanSpeed speed
PWM CONTROLLER 4 FAN.zip (96.2 KB)
Well - get rid of the delay(1000); // ATRASO EM MILI SEGUNDOS PRA ESTABILIDADE in your loop and things will go faster...
Also check the missing {} for the if the temp is in between min and max... that’s probably an issue
Should look like this
if (condition) {
   Instruction1;
   Instruction2;
   Instruction3;
if you do
if (condition)
   Instruction1;
Instruction2;
Instruction3;
then only instruction1 is conditional, Instruction2 and Instruction3 will always get executed (regardless of indentation)
And instead of having an excise in counting,
OR give variables useful names
//if it's the CPU, why on earth don't you just call it
const byte CpuTempPin = A3; // PINO ANALOGICO (CPU) PRA USAR O LM35
(also note the const and the switch to byte because that's already big enough.
OR just work with arrays and reduce the code to 1/4th of it's size :slight_smile:
And depending on the board and the temperature sensors, you can increase the precision/resolution of the readings quite significantly by using internal reference voltage: Arduino Playground - LM35HigherResolution
Danois90:
I solved by modifying the code and adding 100 samples of temperature, it was infinitely more stable !!!
Thanks friends for the help!
Here is the correct code:
Many things can be improved...and there is one bug
The bug is that (on a UNO or similar) an int cannot store the sum of 100x a value that can go up to 1023... use unsigned long to accumulate the readings. Note that You don’t need to read analog entry 100x to be stable - reading twice should be enough unless your temperature varies hyper quickly within a few milliseconds (in which case you should lower the duration of the delay)
Your delay(1000); would fit better at the very end of the loop
pins are best defined as const byte rather than int.
Your PC is fast, there is no need to go slow on Serial, use Serial.begin(115200); instead of 9600 and of course set the serial console at 115200 bauds in the pop up
Give meaningful names to your variable and write appropriate comments
Your code repeats 4 times something similar. Using arrays and a for loop would make your code smaller
Also Please correct your posts above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
