Hello, im trying to build up a robotic vehicle that moves based on the user need, the moving command will be sent through a TCP server, i've setup the server and attached a GSM shield to receive the required command, now im trying to write the c program for the motor drive and i need your opinion, it's a first sketch, i couldn't find a program for my shield, my shield is dagu 4 channel motor controller Dagu 4 Channel DC Motor Controller with Encoder Support for Rover 5 Chassis
the program i wrote is a testing program, based on it the vehicle should move forward for 10 secs then turn left for 1.2 secs then move backward for 5 secs and turn right, i need a confirmation on the code, i'll add the current overload function at the start, and replace the cases with the commands i am receiving, the vehicle is 4 wheels with 4 motors, anything i should add?
#define motorpin0 2 // Direction ch1 front right motor
#define motorpin1 3 // Direction ch2 front left motor
#define motorpin2 4 // Direction ch3 back right motor
#define motorpin3 7 // Direction ch4 back left motor
#define speedpin0 5 //Speed Ch1
#define speedpin1 6 //Speed Ch2
#define speedpin2 9 //Speed Ch3
#define speedpin3 10 //Speed Ch4
int count=0;
//the motor control wires are outputs
pinMode (motorpin0, OUTPUT);
pinMode(motorpin1, OUTPUT);
pinMode(motorpin2, OUTPUT);
pinMode(motorpin3, OUTPUT);
//PWM Pins are outputs
pinMode(speedpin0, OUTPUT);
pinMode(speedpin1, OUTPUT);
pinMode(speedpin2, OUTPUT);
pinMode(speedpin3, OUTPUT);
analogWrite(speedpin0,255);
analogWrite(speedpin1,255);
analogWrite(speedpin2,255);
analogWrite(speedpin3,255);
switch (count)
case 0: //forward
digitalWrite(motorpin0,1);
digitalWrite(motorpin1,1);
digitalWrite(motorpin2,1);
digitalWrite(motorpin3,1);
delay(10000);
count++;
case 1: //Turn right
analogWrite(speedpin0,50);
analogWrite(speedpin2,50);
delay(1200);
count++;
case 2: //backward
digitalWrite(motorpin0,0);
digitalWrite(motorpin1,0);
digitalWrite(motorpin2,0);
digitalWrite(motorpin3,0);
delay (5000);
count++;
case 3: //Turn left
analogWrite(speedpin1,50);
analogWrite(speedpin3,50);
delay(1200);
count++;
