4 channel relay and google assistant with D1 mini
I need help with programming.
Blynk program:
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth = “GMUVXXUvUR98mdd3K0YPozbkrr5lMb58”;
// Your WiFi credentials.
// Set password to “” for open networks.
char ssid = “ASUS”;
char pass = “97983740”;
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
Blynk.run();
RGB Program:
// Load Wi-Fi library
// Replace with your network credentials
const char* ssid = “pcnet-386”; // Input your wifi network name
const char* password = “3rdbencher3c”; // Input your wifi password
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String relay1State = “off”;
String relay2State = “off”;
String relay3State = “off”;
// Assign output variables to GPIO pins
const int relay1 = 14; // GPIO14 D5
const int relay2 = 12; // GPIO12 D6
const int relay3 = 13; // GPIO13 D7
// Initialize the output variables as outputs
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
// Set outputs to HIGH. relay active LOW
digitalWrite(relay1, HIGH);
digitalWrite(relay2, HIGH);
digitalWrite(relay3, HIGH);
// Connect to Wi-Fi network with SSID and password
Serial.print(“Connecting to “);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(”.”);
// Print local IP address and start web server
Serial.println("");
Serial.println(“WiFi connected.”);
Serial.println("IP address: ");
server.begin();
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println(“New Client.”); // print a message out in the serial port
String currentLine = “”; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client’s connected
if (client.available()) { // if there’s bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == ‘\n’) { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that’s the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what’s coming, then a blank line:
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-type:text/html”);
client.println(“Connection: close”);
client.println();
// turns the GPIOs on and off
if (header.indexOf(“PUT /14/on”) >= 0)
Serial.println(“GPIO 14 on”);
relay1State = “on”;
digitalWrite(relay1, LOW);
else if (header.indexOf(“PUT /14/off”) >= 0)
Serial.println(“GPIO 14 off”);
else if (header.indexOf(“PUT /12/on”) >= 0) {
Serial.println(“GPIO 12 on”);
relay2State = “on”;
digitalWrite(relay2, LOW);
else if (header.indexOf(“PUT /12/off”) >= 0) {
Serial.println(“GPIO 12 off”);
else if (header.indexOf(“PUT /13/on”) >= 0)
Serial.println(“GPIO 13 on”);
relay3State = “on”;
digitalWrite(relay3, LOW);
else if (header.indexOf(“PUT /13/off”) >= 0)
Serial.println(“GPIO 13 off”);
// Display the HTML web page
client.println("");
client.println("<meta name=“viewport” content=“width=device-width, initial-scale=1”>");
client.println("<link rel=“icon” href=“data:,”>");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println(“html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}”);
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 12px 24px;");
client.println(“text-decoration: none; font-size: 20px; margin: 2px; cursor: pointer;}”);
client.println(".button2 {background-color: #77878A;}");
// Web Page Heading
client.println(“
NodeMCU Web Server
// Display current state, and ON/OFF buttons for GPIO 5
client.println(“
Relay 1 - State " + relay1State + “
// If the relay1State is off, it displays the ON button
if (relay1State == “off”) {
client.println(”
<a href="/5/on"><button class=“button”>ON
client.println("
<a href="/5/off"><button class=“button button2”>OFF
// Display current state, and ON/OFF buttons for GPIO 4
client.println(“
Relay 2 - State " + relay2State + “
// If the relay2State is off, it displays the ON button
if (relay2State == “off”) {
client.println(”
<a href="/4/on"><button class=“button”>ON
client.println("
<a href="/4/off"><button class=“button button2”>OFF
// Display current state, and ON/OFF buttons for GPIO 0
client.println(“
Relay 3 - State " + relay3State + “
if (relay3State == “off”) {
client.println(”
<a href="/0/on"><button class=“button”>ON
client.println("
<a href="/0/off"><button class=“button button2”>OFF
client.println("");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = “”;
} else if (c != ‘\r’) { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = “”;
// Close the connection
client.stop();
Serial.println(“Client disconnected.”);
Serial.println("");
This project aims to use google assistant to control RGB LED strips. Is the black wire supposed to be connected to V+ ?
I uploaded the above 2 codes to the D1 mini, but when testing, the 3 relays didn’t activate, send help thanks a lot.
Pleas first of all format the code as code see How to use this forum
than it becomes more readable and I might actually look at it when I'm not busy...
secondly: did you do any debugging besides of "relays don't activate"?
Do you know if it's a hardware or software error (e.g. have you checked wether or not the output pins get the correct reading)? Without having read the code in detail, you do some wifi shenanigans, have you checked if the device correctly connects to the wifi etc.?
