Good day guys!!... i jus want to ask on what is the problem with may 4 channel relay.... IN 2..
because this is what happen. when I try to switch it on the led light turns off but the problem is i can't here tick sound then if i plug any appliances in to it is always turn on ieven tough the light is on or off.....
but if i switch the IN 1, IN 3, and IN 4 then last the IN 2 then it works fine??
Can you make a schematic? (NO Fritzing breadboard view, pen and paper drawing will do)
What is powering the relays? If the Arduino, what is powering the Arduino then?
Sounds like your relay contacts are sticking together. This can happen if the relay is faulty or you are passing too much current through the relay contacts. The clicking of the other relays could just dislodge the sticking relay.
