I am brand new to arduino and I have been experimenting with coding the things for the past few weekends. I have used basic and visual basic in the past but it has been a while. I have almost no experience in C++. This is the project where I think I might have learned how a subroutine works and how to make libraries. If I take the entire bottom part of the code and save it as an .h file I think that is a library right? This is what I came up with and its a work in progress. I hope this might be able to help others that are starting off too!!
I installed RGB leds under the desk components in my office/ electronics lab with the intention of connecting them to a home automation system. The home automation system (still trying to make this part) will communicate different messages based on colors and blink patterns of leds. When its not telling me a message I want it to do blinky stuff to music. At some point I need to get a pwm chip to make more outputs. I think I figured out what to do with that but any ideas would be helpful to get that last channel by itself. Let me know what you think and like I said I hope this helps other people!
link to video
// This code was written by jx02123
// I have 5 lights connected to this setup and I tried to use the digital outputs because I didnt have enough PWM. It didnt work so most of the commands are written to use 4 lights.
// Anywhere the redp, greenp, and bluep are located are just turned off to leave if I come back to mess around with that.
// address whatever your pinouts for your rgb leds are here. I have my led strips connected and controled by tip 122 transistors.
int red1 = 10;
int green1 = 9;
int blue1 = 8;
int red2 = 7;
int green2 = 6;
int blue2 = 5;
int red3 = 13;
int green3 = 12;
int blue3 = 11;
int red4 = 4;
int green4 = 3;
int blue4 = 2;
int redp = 22;
int greenp = 24;
int bluep = 26;
// general delays that I have been using inbetween different effects
int ntime = 75;
int dtime = 300;
void setup(){
digitalWrite(redp, LOW);
digitalWrite(bluep, LOW);
digitalWrite(greenp, LOW);
analogWrite(red1, 0);
analogWrite(blue1, 0);
analogWrite(green1, 0);
analogWrite(red2, 0);
analogWrite(blue2, 0);
analogWrite(green2, 0);
analogWrite(red3, 0);
analogWrite(blue3, 0);
analogWrite(green3, 0);
analogWrite(red4, 0);
analogWrite(blue4, 0);
analogWrite(green4, 0);
rotateR(255,255,0,75);
rotateR(255,0,0,75);
rotateR(0,0,255, 75);
rotateR(0,255,0,75);
rotateR(255,255,255,50);
void all(int r, int g, int b) //ALL Lights (r, g, b)
analogWrite(red1, r);
analogWrite(blue1, b);
analogWrite(green1, g);
analogWrite(red2, r);
analogWrite(blue2, b);
analogWrite(green2, g);
analogWrite(red3, r);
analogWrite(blue3, b);
analogWrite(green3, g);
analogWrite(red4, r);
analogWrite(blue4, b);
analogWrite(green4, g);
void light1 (int r, int g, int b)
void light2 (int r, int g, int b)
void light3 (int r, int g, int b)
void light4 (int r, int g, int b)
void blinkall (int r, int g, int b, int R, int G, int B, int d)
all(r, g, b);
delay(d);
all(R, G, B);
delay(d);
all(r, g, b);
delay(d);
all(R, G, B);
delay(d);
all(r, g, b);
delay(d);
all(R, G, B);
delay(d);
all(r, g, b);
delay(d);
all(R, G, B);
delay(d);
all(r, g, b);
delay(d);
all(R, G, B);
delay(d);
all(r, g, b);
delay(d);
all(R, G, B);
delay(250);
void blinkright(int r, int g, int b, int R, int G, int B, int d)// lowercase and uppercase are the two colors to blink back and forth. If you wanted you can blink green and red with 255,0,0,0,255,0,100 for example with a delay time of 100. It pauses at the end for twice the delay
right(r, g, b);
delay(d);
right(R, G, B);
delay(d);
right(r, g, b);
delay(d);
right(R, G, B);
delay(d);
right(r, g, b);
delay(d);
right(R, G, B);
delay(d);
right(r, g, b);
delay(d);
right(R, G, B);
delay(d);
right(r, g, b);
delay(d);
right(R, G, B);
delay(d);
right(r, g, b);
delay(d);
right(R, G, B);
delay(d*2);
void blinkleft(int r, int g, int b, int R, int G, int B, int d)
left(r, g, b);
delay(d);
left(R, G, B);
delay(d);
left(r, g, b);
delay(d);
left(R, G, B);
delay(d);
left(r, g, b);
delay(d);
left(R, G, B);
delay(d);
left(r, g, b);
delay(d);
left(R, G, B);
delay(d);
left(r, g, b);
delay(d);
left(R, G, B);
delay(d);
left(r, g, b);
delay(d);
left(R, G, B);
delay(250);
void right (int r, int g, int b)// this is the right half of the light display turning the left off
light3(r, g, b);
light4(r, g, b);
light1(0,0,0);
light2(0,0,0);
void left (int r, int g, int b) // this is the left half of the light display turning the right off
light1 (r, g, b);
light2 (r, g, b);
light3 (0,0,0);
light4 (0,0,0);
void rotateR(int r, int g, int b, int d) // rotates to the right one light at a time with short pause at end = to double delay set
all(0,0,0);
light1(r,g,b);
delay(d);
all(0,0,0);
light2(r,g,b);
delay(d);
all(0,0,0);
light3(r,g,b);
delay(d);
all(0,0,0);
light4(r,g,b);
delay(2*d);
all(0,0,0);
void rotateL(int r, int g, int b, int d) // rotates to the left one light at a time with short pause at end = to double delay set
all(0,0,0);
light4(r,g,b);
delay(d);
all(0,0,0);
light3(r,g,b);
delay(d);
all(0,0,0);
light2(r,g,b);
delay(d);
all(0,0,0);
light1(r,g,b);
delay(2*d);
all(0,0,0);
