Hello! I can't make the alarm to trigger at the alarm times that are stored in the eeprom.
This is the code
#include <LiquidCrystal.h>
#include <EEPROM.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// Timer variables
int hours[4] = {0, 0, 0, 0};
int minutes[4] = {0, 0, 0, 0};
int seconds[4] = {0, 0, 0, 0};
unsigned long startTime[4] = {0, 0, 0, 0};
const unsigned long updateInterval = 1000;
// Button pins
const int buttonPins[5] = {6, 7, 8, 9, 10};
int buttonStates[5] = {HIGH, HIGH, HIGH, HIGH, HIGH};
// Alarm variables
int alarmHours[4] = {0, 0, 0, 0};
int alarmMinutes[4] = {0, 0, 0, 0};
bool alarmEnabled[4] = {false, false, false, false};
// Setting mode
int settingChannel = -1;
// Buzzer pin
const int buzzerPin = 13;
unsigned long buttonPressTime[4] = {0, 0, 0, 0};
unsigned long alarmStartTime[4] = {0, 0, 0, 0};
// Global variable declaration
bool setButtonPressed = false;
bool alarmSettingMode = false;
bool displayNeedsUpdate = true;
// Function declarations
void readAlarmsFromEEPROM();
void writeAlarmsToEEPROM();
void checkAlarm(int channel);
void resetTimer(int channel);
void stopAlarm(int channel);
void displayTimers();
void updateTimer(int channel);
void printTime(int h, int m);
void readButtons();
void handleButtons();
void displayAllAlarms();
void displayAlarmSettings(int channel);
lcd.begin(16, 2);
Serial.begin(9600); // Initialize Serial communication
for (int i = 0; i < 4; i++) {
startTime[i] = millis();
for (int i = 0; i < 5; i++) {
pinMode(buttonPins[i], INPUT_PULLUP);
pinMode(buzzerPin, OUTPUT);
displayTimers();
unsigned long currentTime = millis();
bool anyTimerUpdated = false;
if (currentTime - startTime[i] >= updateInterval) {
startTime[i] += updateInterval;
seconds[i]++;
if (seconds[i] >= 60) {
seconds[i] = 0;
minutes[i]++;
if (minutes[i] >= 60) {
minutes[i] = 0;
hours[i]++;
if (hours[i] >= 100) {
hours[i] = 0;
checkAlarm(i);
startTime[i] = currentTime;
if (!alarmSettingMode) {
updateTimer(i);
anyTimerUpdated = true;
readButtons();
handleButtons();
if (displayNeedsUpdate || anyTimerUpdated) {
if (alarmSettingMode) {
displayAllAlarms();
displayTimers();
displayNeedsUpdate = false;
void displayTimers() {
static int previousHours[4] = { -1, -1, -1, -1 };
static int previousMinutes[4] = { -1, -1, -1, -1 };
static int previousSeconds[4] = { -1, -1, -1, -1 };
if (hours[i] != previousHours[i] ||
minutes[i] != previousMinutes[i] ||
seconds[i] != previousSeconds[i]) {
lcd.setCursor((i % 2) * 8, i / 2);
lcd.print(i + 1);
lcd.print("-");
if (hours[i] > 0) {
printTime(hours[i], minutes[i]);
printTime(minutes[i], seconds[i]);
lcd.print(" ");
previousHours[i] = hours[i];
previousMinutes[i] = minutes[i];
previousSeconds[i] = seconds[i];
void updateTimer(int channel) {
if (hours[channel] != previousHours[channel] ||
minutes[channel] != previousMinutes[channel] ||
seconds[channel] != previousSeconds[channel]) {
int cursorPosition = (channel < 2) ? (channel * 8 + 2) : ((channel - 2) * 8 + 2);
int row = (channel < 2) ? 0 : 1;
lcd.setCursor(cursorPosition, row);
if (hours[channel] > 0) {
printTime(hours[channel], minutes[channel]);
printTime(minutes[channel], seconds[channel]);
previousHours[channel] = hours[channel];
previousMinutes[channel] = minutes[channel];
previousSeconds[channel] = seconds[channel];
void printTime(int h, int m) {
if (h < 10) lcd.print("0");
lcd.print(h);
lcd.print(":");
if (m < 10) lcd.print("0");
lcd.print(m);
void readButtons() {
buttonStates[i] = digitalRead(buttonPins[i]);
void handleButtons() {
static unsigned long lastSetButtonReleaseTime = 0;
if (buttonStates[4] == LOW) {
if (!setButtonPressed) {
alarmSettingMode = true;
setButtonPressed = true;
bool alarmUpdated = false;
if (buttonStates[i] == LOW) {
alarmMinutes[i]++;
if (alarmMinutes[i] >= 60) {
alarmMinutes[i] = 0;
alarmHours[i]++;
if (alarmHours[i] >= 100) {
alarmHours[i] = 0;
alarmUpdated = true;
delay(150);
if (alarmUpdated) {
lastSetButtonReleaseTime = currentTime;
if (alarmHours[i] != 0 || alarmMinutes[i] != 0) {
alarmEnabled[i] = true;
if (buttonPressTime[i] == 0) {
buttonPressTime[i] = currentTime;
if (currentTime - buttonPressTime[i] > 500) {
resetTimer(i);
if (buttonPressTime[i] != 0 && currentTime - buttonPressTime[i] <= 500) {
stopAlarm(i);
buttonPressTime[i] = 0;
void displayAllAlarms() {
lcd.clear();
lcd.print(i + 1);
lcd.print("-");
printTime(alarmHours[i], alarmMinutes[i]);
void displayAlarmSettings(int channel) {
lcd.clear();
lcd.print("Set alarm ");
lcd.print(channel + 1);
lcd.setCursor(0, 1);
lcd.print(alarmHours[channel]);
lcd.print(":");
lcd.print(alarmMinutes[channel]);
void checkAlarm(int channel) {
static bool blinkState[4] = {false, false, false, false};
static unsigned long previousMillis[4] = {0, 0, 0, 0};
const int blinkInterval = 250;
Serial.print("Channel: ");
Serial.print(channel);
Serial.print(", Enabled: ");
Serial.print(alarmEnabled[channel]);
Serial.print(", Alarm Time: ");
Serial.print(alarmHours[channel]);
Serial.print(":");
Serial.print(alarmMinutes[channel]);
if (alarmEnabled[channel] && (alarmHours[channel] != 0 && alarmMinutes[channel] != 0)) {
unsigned long elapsedTime = hours[channel] * 60 + minutes[channel];
unsigned long alarmTime = alarmHours[channel] * 60 + alarmMinutes[channel];
Serial.print(", Elapsed Time: ");
Serial.print(elapsedTime);
Serial.print(", Alarm Time (min): ");
Serial.println(alarmTime);
if (elapsedTime >= alarmTime) {
Serial.println("Alarm Triggered!"); // Debugging message
tone(buzzerPin, 1000);
if (alarmStartTime[channel] == 0) {
alarmStartTime[channel] = millis();
if (millis() - alarmStartTime[channel] >= 2000) {
noTone(buzzerPin);
alarmStartTime[channel] = 0;
if (currentMillis - previousMillis[channel] >= blinkInterval) {
previousMillis[channel] = currentMillis;
blinkState[channel] = !blinkState[channel];
lcd.setCursor((channel % 2) * 8, channel / 2);
if (blinkState[channel]) {
lcd.print("-");
lcd.print(" ");
lcd.print(" ");
noTone(buzzerPin);
lcd.print("-");
lcd.print(" ");
Serial.println(); // Just a newline for clarity
void resetTimer(int channel) {
hours[channel] = 0;
minutes[channel] = 0;
seconds[channel] = 0;
updateTimer(channel);
void stopAlarm(int channel) {
alarmEnabled[channel] = false;
noTone(buzzerPin);
displayTimers();
void readAlarmsFromEEPROM() {
int hour = EEPROM.read(i * 2);
int minute = EEPROM.read(i * 2 + 1);
if (hour >= 0 && hour < 100 && minute >= 0 && minute < 60) {
alarmHours[i] = hour;
alarmMinutes[i] = minute;
alarmHours[i] = 0;
void writeAlarmsToEEPROM() {
EEPROM.write(i * 2, alarmHours[i]);
EEPROM.write(i * 2 + 1, alarmMinutes[i]);
And this is the hardware:
"version": 1,
"editor": "wokwi",
"parts": [
{ "type": "wokwi-arduino-nano", "id": "arduino", "top": 100, "left": 100, "attrs": {} },
"type": "wokwi-lcd1602",
"id": "lcd",
"top": -217.37,
"left": 121.6,
"attrs": { "contrast": "0.7" }
"type": "wokwi-pushbutton",
"id": "button1",
"top": 270,
"left": 50,
"attrs": { "color": "red" }
"id": "button2",
"top": 270,
"left": 110,
"attrs": { "color": "green" }
"id": "button3",
"top": 270,
"left": 170,
"attrs": { "color": "blue" }
"id": "button4",
"top": 270,
"left": 230,
"attrs": { "color": "yellow" }
"id": "setbutton",
"top": 275,
"left": 307.2,
"attrs": { "color": "black" }
{ "type": "wokwi-buzzer", "id": "buzzer", "top": 12, "left": 337.8, "attrs": {} }
"connections": [
[ "lcd:RS", "arduino:12", "green", [ "v0" ] ],
[ "lcd:EN", "arduino:11", "green", [ "v0" ] ],
[ "lcd:D4", "arduino:5", "green", [ "v0" ] ],
[ "lcd:D5", "arduino:4", "green", [ "v0" ] ],
[ "lcd:D6", "arduino:3", "green", [ "v0" ] ],
[ "lcd:D7", "arduino:2", "green", [ "v0" ] ],
[ "lcd:VCC", "arduino:5V", "green", [ "v0" ] ],
[ "lcd:GND", "arduino:GND.1", "green", [ "v0" ] ],
[ "lcd:LED+", "arduino:5V", "green", [ "v0" ] ],
[ "lcd:LED-", "arduino:GND.1", "green", [ "v0" ] ],
[ "lcd:VO", "arduino:GND.1", "green", [ "v0" ] ],
[ "lcd:VSS", "arduino:GND.1", "green", [ "v0" ] ],
[ "lcd:VDD", "arduino:5V", "green", [ "v0" ] ],
[ "lcd:E", "arduino:11", "green", [ "v0" ] ],
[ "button1:1", "arduino:6", "green", [ "v0" ] ],
[ "button1:2", "arduino:GND.2", "green", [ "v0" ] ],
[ "button2:1", "arduino:7", "green", [ "v0" ] ],
[ "button2:2", "arduino:GND.2", "green", [ "v0" ] ],
[ "button3:1", "arduino:8", "green", [ "v0" ] ],
[ "button3:2", "arduino:GND.2", "green", [ "v0" ] ],
[ "button4:1", "arduino:9", "green", [ "v0" ] ],
[ "button4:2", "arduino:GND.2", "green", [ "v0" ] ],
[ "setbutton:1", "arduino:10", "green", [ "v0" ] ],
[ "setbutton:2", "arduino:GND.2", "green", [ "v0" ] ],
[ "buzzer:1", "arduino:13", "green", [ "v0" ] ],
[ "buzzer:2", "arduino:GND.3", "green", [ "v0" ] ]
"dependencies": {}
Link to the project:
Just to specify that I have a minimum amount of programming capabilities, I made all this with chat gpt assisted by gemini ai😀. I'm struggling to get this working since 1 week now, if someone can help me will be very good for my mental sanity that is already falling apart!
