thank you so much wildbill you are a start (paul sends wildbill a crate of beer)
ok once you pointed out the error of my ways i rewrote the sketch doing away with the wait command it all works well appart from intermitent servo jitter any ideas how i might minimise this
thanks again mike and wildbill for taking the time out to help a novice like me
paul
ps my new sketch below:-
#include <Servo.h>
int minPulse1 = 0; // minimum servo position
int maxPulse1 = 170; // maximum servo position
int turnRate1 = 10; // servo turn rate increment (larger value, faster rate)
int minPulse2 = 0; // minimum servo position
int maxPulse2 = 180; // maximum servo position
int turnRate2 = 10; // servo turn rate increment (larger value, faster rate)
//int buttonPin = 26; // pin that the trigger will be connected to
/** The Arduino will calculate these values for you **/
// connect apc220 after sketch upload to control wirelessly through serial monitor
int EN1 = 3; //speed control
int EN2 = 5; //speed control
int EN3 = 6; //speed control
int EN4 = 9; //speed control
int IN1 = 2; //direction
int IN2 = 4; //direction
int IN3 = 7; //direction
int IN4 = 8; //direction
void Motor1(int pwm, boolean reverse)
analogWrite(EN1,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
if(reverse)
digitalWrite(IN1,HIGH);
digitalWrite(IN1,LOW);
void Motor2(int pwm, boolean reverse)
analogWrite(EN2,pwm);
if(reverse)
digitalWrite(IN2,HIGH);
digitalWrite(IN2,LOW);
void Motor3(int pwm, boolean reverse)
analogWrite(EN3,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
if(reverse)
digitalWrite(IN3,HIGH);
digitalWrite(IN3,LOW);
void Motor4(int pwm, boolean reverse)
analogWrite(EN4,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
if(reverse)
digitalWrite(IN4,HIGH);
digitalWrite(IN4,LOW);
Servo servo1;
Servo servo2;
int centerServo1;
int centerServo2;
int pulseWidth1;
int pulseWidth2; // servo pulse width
//pinMode(buttonPin, OUTPUT);
servo1.attach(10);
servo2.attach(11);
centerServo1 = maxPulse1 - ((maxPulse1 - minPulse1)/2);
centerServo2 = maxPulse2 - ((maxPulse2 - minPulse2)/2);
pulseWidth1 = centerServo1;
pulseWidth2 = centerServo2;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
Serial.println("Arduino Serial DC Motor Control");
Serial.println("Press a, d, w, or x to move, s to stop");
Serial.println("Arduino Serial Servo Control");
Serial.println("Press j, l, i, or k to move, spacebar to center, and f to fire");
int i;
for(i=2;i<=9;i++) //Motor Shield pin settings
pinMode(i, OUTPUT); //set pin 3,4,5,6,7,8,9, to output mode
// check for serial input
if (Serial.available() > 0) {
char data = Serial.read(); // read the incoming byte:
//digitalWrite(buttonPin, LOW); // turn the pin off on any incoming data
switch(data)
case 'w': //Move ahead
Motor1(150,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor2(150,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor3(150,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor4(150,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
case 'x': //move back
Motor1(150,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor2(150,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor3(150,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor4(150,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
case 'a': //turn left
Motor1(250,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor2(250,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor3(250,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor4(250,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
case 'd': //turn right
Motor1(250,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor2(250,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor3(250,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
Motor4(250,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
case 's': //stop
Motor1(0,false);
Motor2(0,false);
Motor3(0,false);
Motor4(0,false);
case 'j' :
pulseWidth1 = pulseWidth1 - turnRate1;
case 'l' :
pulseWidth1 = pulseWidth1 + turnRate1;
break ;
case ' ' :
pulseWidth1 = pulseWidth2 = centerServo1;
case 'i' :
pulseWidth2 = pulseWidth2 - turnRate1;
case 'k' :
pulseWidth2 = pulseWidth2 + turnRate1;
break ;
case 'f' :
//digitalWrite(buttonPin, HIGH);
delay (1000);
// stop servo pulse at min and max
if (pulseWidth1 > maxPulse1) {
pulseWidth1 = maxPulse1;
if (pulseWidth1 < minPulse1) {
pulseWidth1 = minPulse1;
if (pulseWidth2 > maxPulse2) {
pulseWidth2 = maxPulse2;
if (pulseWidth2 < minPulse2) {
pulseWidth2 = minPulse2;
servo1.write(pulseWidth1);
servo2.write(pulseWidth2);
// print pulseWidth back to the Serial Monitor (uncomment to debug)
Serial.print("Servo 1: ");
Serial.print(pulseWidth1);
Serial.print(" Servo 2: ");
Serial.print(pulseWidth2);
Serial.println("degrees");
