4 digit 7-segment ARK:SR410561N 1332 w/ Arduino Uno
I am having trouble with this project I am doing. I am trying to make a digital scale using an Uno and a 4 digit 7 segment SR410561N. I am also using a 1k pot to use as the values for my digital scale. The numbers are reading right but I am having a trouble displaying different numbers for each digit at the same time because its not being put in serially. I don't really understand how I would be able to accomplish it with just the hardware at hand. I am open to many suggestions if possible! Here is the code I have so far.
#define ON HIGH
#define OFF LOW
// segment should be low
int digit1=2;
int digit2=3;
int digit3=4;
int digit4=5;
int arrayD[]= {digit1, digit2, digit3, digit4};
int segA=6;
int segB=7;
int segC=8;
int segD=9;
int segE=10;
int segF=11;
int segG=12;
int segDot = 13;
int potPin = 5;
int val = 0;
float voltage;
int digiScale[4];
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(segDot, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
void loop(){
val = analogRead(potPin);
Serial.println(val);
voltage = val * (5.0 / 1023.0);
Serial.println(voltage);
Serial.print("\n");
// int reset = 0;
// int dot;
// switch(dot){
// case 1:
// digitalWrite(digit1, ON);
// break;
// case 2:
// digitalWrite(digit2, ON);
// break;
// case 3:
// digitalWrite(digit3, ON);
// break;
// case 4:
// digitalWrite(digit4, ON);
// break;
//digitalWrite(digit1, ON);
//digitalWrite(digit2, ON);
//digitalWrite(digit3, ON);
//digitalWrite(digit4, ON);
//delay(1000);
Serial.println("\n");
int one = val % 10;
Serial.println(one);
int two = val % 100/10;
Serial.println(two);
int three = val % 1000 / 100;
Serial.println(three);
int four = val / 1000;
Serial.println(four);
digiScale[0] = four;
digiScale[1] = three;
digiScale[2] = two;
digiScale[3] = one;
if (digit1 == 1){
numbers(digiScale[0]);
if (digit2 == 1){
numbers(digiScale[1]);
if (digit3 == 1){
numbers(digiScale[2]);
if (digit4 == 1){
numbers(digiScale[3]);
dispScale();
digitalWrite(digit1, OFF);
digitalWrite(digit2, OFF);
digitalWrite(digit3, OFF);
digitalWrite(digit4, OFF);
//numbers(digiScale[3]);
//digitalWrite(digit2, OFF);
//digitalWrite(digit3, OFF);
//digitalWrite(digit4, OFF);
//delay(100);
//numbers(digiScale[2]);
//numbers(digiScale[1]);
//numbers(digiScale[0]);
//digitalWrite(digit1, OFF);
//delay(1000);
void numbers(int digit){
// delay(1000);
switch(digit){
case 0:
digitalWrite(segA, OFF);
digitalWrite(segB, OFF);
digitalWrite(segC, OFF);
digitalWrite(segD, OFF);
digitalWrite(segE, OFF);
digitalWrite(segF, OFF);
digitalWrite(segG, ON);
case 1:
digitalWrite(segA, ON);
digitalWrite(segD, ON);
digitalWrite(segE, ON);
digitalWrite(segF, ON);
case 2:
digitalWrite(segC, ON);
digitalWrite(segG, OFF);
case 3:
case 4:
case 5:
digitalWrite(segB, ON);
case 6:
case 7:
case 8:
case 9:
case 10:
void dispScale(){
for(int i = 0; i < 4; i++){
digitalWrite(arrayD*, ON);*
_ numbers(digiScale*);_
_
Serial.print("\n");_
_
delay(1000);_
_
}_
_
delay(2000);_
_
numbers(10);_
_
}*_
//Also all leds are connected with resistors.
Sorry, I cleaned up the code a little bit.
#define ON HIGH
#define OFF LOW
int digit1=2;
int digit2=3;
int digit3=4;
int digit4=5;
int segA=6;
int segB=7;
int segC=8;
int segD=9;
int segE=10;
int segF=11;
int segG=12;
int segDot = 13;
int potPin = 5;
int val = 0;
float voltage;
int digiScale[4];
void loop(){
Serial.print("\n");
//delay(1000);
i0nt one = val % 10;
digiScale[2] = two;
digiScale[3] = one;
dispScale();
switch(digit){
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
void dispScale(){
_
delay(1000);_
_
}_
_
delay(2000);_
_
numbers(10);_
_
}*_
Maybe, but you still didn't read the forum rules...
Did you notice some of parts of your sketch are missing and other parts are in italics?
I saw that what I deleted isn't there anymore so that it can be easier to read. I did see a typo on my part i0nt one should be int one. I don't see any missing parts. The parts in italics does not give me any problems.
Agal:
No, it gives problems to those who would like to help you.
Look at this line of your code that I have simply copied and pasted here:
   digitalWrite(arrayD, ON);
does that look the same as the line of code in your sketch? Can you see what is missing yet?
How do you have the hardware wired?
I have a 4 digit 7 segment (7 line plus a decimal) common cathode display. What I did to display 4 different numbers was to multiplex the display. You can only show 1 digit at a time because that's the only way to have complete control over all segments individually. So you must quickly and continuously run a function to draw each individual digit, at a very fast rate to trick the eye into seeing it as a whole.
I'm on my android right now so I don't have access the code rn, but you need to do something like this (untested)
int pointer = 0;
void tick()
if (pointer > 3)
   pointer = 0;
int pin = arrayD[pointer];
int lastpin;
if(pointer == 0)
   lastpin = arrayD[3]; //hop back
else lastpin = arrayD[pointer  - 1]; //one to the left/right
digitalWrite(lastpin, HIGH); //disable last digit
//add code here for drawing segments for digit 'pointer', where 0 is first digit, 3 is last.
digitalWrite(pin , LOW ); //enable current digit
pointer++;
Now the best thing to call this function is with an ISR, and call this function every 2 millisecond or so. If you can't get that working, you can just put it in loop () with a delay. However, that would limit the rest of the program.
Here is the timer example:
#include <TimerOne.h> //If this doesn't work, you need to download and import the Timer1 arduino library
//then add this to the setup() function:
Timer1.initialize(2000); // set a timer of length 2000 microseconds)
Timer1.attachInterrupt( tick ); // attach the service routine here
Hope this is of help.
Matt
