i don't understand the connection with the 7 segment displays
you mentioned : " Basically the pin 11 connects to the QA, the pin 7 to the QB and so one…"
But pin 11 is going to the 74hc595.
Can you explain?
thanks
It depends... you have to see the datasheet of your 7seg. and connect all in parallel.... u can use the "CD4511" to drive your display... i've done a lot of project with this chip and multiplexed 7seg.
